Question about APC Back-UPS ES 350 - UPS ( external ) - 350 VA - UPS battery lead acid - 6 output connector(s) (NEWITEM13161548) UPS System
Low battery alert on my apc - ups es350
My old unit was about 4 years old and had replaced the battery a few months ago. Began getting a low battery warning after a few months. Decided to change out complete unit. Received and installed exact replacement unit and after a few weeks (maybe 4 or 5) I'm getting the same low battery warning. I tried unpluging some of the appliances from the battery side but doesn't seem to change. The voltage is about 120 when plugged in but drops to 106 - 105 when you unplug the power, and drops about a volt every 15 or 20 secounds. is there anything else I should try before going for a replacement battery
Posted by thevog on
David Wakefield
    New Friend:
  • 3 Answers
If you dropped it the wire may have come off ,,,its just a slip on connection,,,,mine beeped,,,whined and blinked,,,,took off bottom and replaced the wire seems ok now,,,,I shouldn't have dropped it
Posted on Nov 09, 2013
Anonymous
Have your supply voltage and frequency checked under load.
/bz
Posted on Mar 11, 2008
I need to find out a replacement battery for the above. The unit is about 4 years old.
Dear Luke Edmunds
you can replace with 12 V x 16 A x 2 CSB
it is original batteries of APC unet
Mar 25, 2015 | APC Computers & Internet
Apc xs1500 beeps 4 times
Check if the unit has a breaker on the back and reset it. The unit doesn't seem to be getting power.
Dec 03, 2012 | APC 1500VA BX1500 8 Outlet UPS UPS System
How to extract batteries from an APC Smart UPS 1400
greg milton, Hi, Did you get the top cover off of the "1400" battery back-up? How old were the batteries in the unit? My APC 1250 has two 12v 18ah units inside. It's best to replace batteries every 3 to 5 years! 12fixlouie
Aug 20, 2010 | NEC APC Smart-UPS 1400 (050-01803-000) UPS...
Smart apc ups error with all indicator flashing .
APC Smart-UPS 1500VA has an error. All it's pannel lights blinking. what is the best possible solution to this?
Jun 14, 2010 | APC Smart-UPS 1500VA Shipboard...
My APC BE500U keeps resetting
It certainly indictes a problem with the APC unit a replacement bettry may or may not solve the problem. Do you really need one as you have an anti surge protector?
Sep 18, 2009 | APC 500VA BE500U Back-UPS ES...
Failing APC 3000s
  • old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball
Feb 09, 2009 | APC (SUA3000I) UPS System
1995 Saturn SL2 Continues To Stall
I had same problem a couple years ago with 95 sl2, i had new wires and plugs instaled and they replaced the valves also. car works great since then...
Jan 07, 2009 | Saturn SL2 Cars & Trucks
APC ES350 strange noise
My solution was to unplug everything, hit the reset button, and then power the unit back up. The problem I found to be that I had my laser printer connected to the "surge + battery" side, and for some reason no laser printer can be connected to it.
Sep 28, 2008 | APC Back-UPS ES 350 - UPS ( external ) -...
Unit is switching to battery power for now reason.
Any UPS monitors the incoming AC level to determine if it is needed or not.  I think the APC unit doesn't know any more when it is needed; it's sick.
Sep 23, 2008 | NEC APC Smart-UPS 1400 (050-01803-000) UPS...
APC Back-UPS ES 350 - UPS ( external ) - 350 VA - UPS battery lead acid - 6 output connector(s) (NEWITEM13161548) UPS System Logo
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Joe Goldman
Joe Goldman
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
