Question about APC Smart-UPS 1000VA UPS System
Smart UPS 1500 - battery level green lights blink on and off
I was wondering if anyone knew why a Smart UPS 1500 battery level ( which has new batteries) would continue to blink on and off green.
The UPS works fine and keeps everything powered up but the battery meter on the front display continues to blink. The lights are green and I have shut down and reset the power ups several times over - lights will set and then start to blink.
Any assistance will be greatly appreciated on anything I can try to solve this issue.
Posted by georgiana_do on
Anonymous
    Scholar:
  • 55 Answers
You need to run recalibration on the unit.  The supplied PowerChute software & cable will allow you to do this if you hook the UPS up to a PC (I know it works with the serial cable, not sure about USB).  If you only have a MAC then I cannot offer a solution other than to buy the standalone PowerView device from APC.  It will cost a bit more than a battery, but may save you from buying needless batteries in the future.  I finally broke down an bought one, but note that I was still having the problem after the 1st recalibration.  By trial and error (and maybe a vague memory) I put my MAC in sleep mode, that dropped the load to stop the lights from flashing.  Then I recalibrated with a 22% load and now it finally seems better (lights no longer flashing).  This was with a Smart-UPS 1000.
Let me know if that helps.
Posted on May 09, 2009
  • ljg1934
    ljg1934 Jun 24, 2012
    Why would you yell "MAC" like that? What makes a Mac so important that you have to scream it?
Sami Sawda
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 65 Answers
You should use the Powerchute business edition software that comes with the UPS to enable you fixing the battery replacement date. when doing so battery green LED (charging level) should stop blinking.
Posted on Dec 02, 2014
  • verstile56789
    verstile56789 Mar 18, 2017
    my APC smart ups 1500VA, when i connect AC Source, and press Test Button, its all 6 LEDs start blinking continues. DID anyone help me how can i remove this fault...
    what hardware need to be replace with good one.>>> please help me.
APC SUA1500RMI2U Smart-UPS . the led blink with red after the test button . it is indicated with cross. continuously blinking & no green indication shown . but ups is running
Hi Juhi,
You may need to replace your batteries. Have you checked battery voltages?
If you need UPS, Surge, or Power Related help contact Daniel with Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/ ** If this helped - click YES :) **
Apr 07, 2014 | APC (SUA1500RMI2U) (0731304197300) UPS...
Blinking lights
The problem is, is that while the unit is not overloaded (too much plugged in) either the batteries are close to failure, OR more likely you have so much plugged in you have less than 2 minutes of runtime.
Try removing some devices, lower the load. The row of green lights on the left is your load level indication, you want no more than 4 lit usually, 80% load is the most recommended. This will allow more runtime and should stop the flashing.
The flashing is just ment to alert you to less than two minutes of runtime.
If you have 80% load or less, and it still flashes, press and hold the on/test button until it clicks over to battery, the unit will now run a self test and switch back to main power after a few seconds and it should stop blinking.
If you want a copy of your user manual, you can find it here: http://www.refurbups.com/KB-M-Smartups (the Smart-UPS 1000)
Apr 08, 2010 | APC Smart-UPS 1000VA UPS System
Hi i just got a 3000 SMART UPS AND WHEN I turn it on, all its lights are blinking. Can anyone help me with this please ?
Chekc if battery are correctly connected.If Yes, the UPS can havea internal failure. Contact you reseller.
Oct 08, 2009 | APC Smart-UPS 1500VA Shipboard...
Beep and yellow green light problem
It sounds like you may need a new battery. The batteries are continuously tested by the UPS and it could be that the voltage is passing one test, and failing the next which is resulting in the light flashing. You can test the battery with a voltmeter. It should read over 11.5 volts, if not you need a new battery set. You can get batteries from http://www.batteryinternational.com/ups-batteries-apc-batteries.html
Jun 20, 2009 | APC VS 500VA (VS500VA) UPS System
APC Smart UPS 1500 will not start.
It could be that the cable to the front-panel got damaged during the battery replacement.  After all these years you would think APC would improve that aspect of their design.  All I can suggest is inspecting the cable and where it connects to the front panel.
Apr 18, 2009 | APC Smart-UPS 1000VA UPS System
I have just replaced the battery of my 1500 smart UPS and all the LED are blinking. What should I do to make it functional as before?
hmmm juz turn off and on the ups also the power source if it not workin you hav to check your setting which u install the software?
Mar 16, 2009 | APC Smart-UPS 1500VA Shipboard...
APC Smart-UPS 1000VA UPS System Logo
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Joe Goldman
Joe Goldman
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
