Rio S50 Street (128 MB) MP3 Player Logo
A
Anonymous Posted on Aug 07, 2012
No driver for rio s50
Don't have product disc. Where can I find and download the correct driver to use in Windows 7?
1 Related Answer
Anonymous
  • 304 Answers
  • Posted on Dec 06, 2010
SOURCE: is the rio carbon disc compatible for windows 7
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_51.jpg
1helpful
Just did a clean install of Windows 7 (64-bit) don't have the original discs. Everything appeasr to be working fine. but what order do i download the drivers in?
It doesn't matter what order you download the drivers. I normally do my network drivers first so that I can use the internet to download the others.
Where can I get a driver for my ge minicam 98756
Hello, Mike!
You can find all GE drivers for computer accessories following this link:
http://www.jascoproducts.com/support/software-downloads.asp
1. Follow the link I provided
2. If you are running Vista or Windows 7, then choose "For Windows 7 & Vista drivers" option; if running Windows 95, 98, 2000 or XP, then simply choose "PC Cams" option by clicking on it.
3. Find your product on the list provided and click to download. The file is .zip, so you will have to unzip it, and then install.
I hope you will find this solution useful.
Thank you for contacting me.
Best regard!
Hajrija Cobo
2answers
I WANT DOWNLOAD SOUND DRIVER MOTHER BOARD GA-8VM533
Go into this page http://www.gigabyte.com/products/product-page.aspx?pid=1731 then enter your operating system and a list of current drivers will appear, choose the ones you need and download..
3answers
Can't download and install printer driver HP Deskjet 1220C for window 7
There is no downloadable driver for this printer. You just need to update the Windows 7 list on your computer with the latest update. Here are the instructions from hp:
The drivers for your HP product are already included in the new Windows 7 operating system! You do not need to download drivers to use the product . Simply connect the printer to your computer with a USB cable, and Windows Update automatically installs the driver for your product. With the in-OS The driver located in the Windows 7 operating systemdriver, some of the buttons on the product do not function and some of the advanced product features are not available. For more information about your in-OS driver, and to see workarounds for lost functionality, go to our Frequently Asked Questions below. Install the Windows 7 in-Operating System (in-OS) print driver When you connect your printer to the computer, Windows 7 detects the hardware and automatically installs the correct driver. A notification lets you know when installation begins and when it is complete. You do not have to download any software or insert the product CD. Step one: Install the in-OS driver Follow these steps to install the in-OS driver in Windows 7. NOTE: The computer must be connected to the Internet for Windows Update to detect and install your product.
  1. Turn the product on.
  2. Connect the USB cable to the printer, and then to the computer. Figure 1: USB cablec01704933.gif NOTE: When you connect the USB cable to the printer, and then to the computer, Windows 7 activates Windows Update. Windows Update searches online for the most recent product driver on the Windows Update site. If the online driver is more recent than the driver stored in Windows 7, the computer downloads and installs the updated driver.The Windows Update process takes place automatically. Therefore, you might not notice that the process is in progress.
  3. Windows 7 detects the hardware and automatically installs the correct driver. A notification displays on your computer to let you know when installation is complete.
Your basic Windows 7 driver is now installed. Some functions might not be available, but you can use workaround procedures instead. See our Frequently Asked Questions section below. Step two: Print a document Print from any software program to make sure your printer is working correctly.
  1. Open a document in the software application in which it was created.
  2. Click File , and then click Print .
HI, i have a IBM thinkcentre S50 8086-21G and after resinstall on my hard drive the XP SP2 version , i don't have access about the USB connector and can you help me about this? i don't find the...
What exactly are you trying to connect to the computer via usb? If your talking about generic devices such as usb mice and keyboard then you will need to reinstall windows again. Devices like these use a generic usb driver that is installed during windows xp installation. There isn't really anyway to install this driver that I am aware of other then a clean install of windows
You could attempt to repair the windows system files, but I can't guarantee it will help.
You will need a windows xp disc. -Insert the disc. -Press the "Start" button -Click on run -Type "cmd" and press enter -Type "sfc /SCANNOW" and press enter
This will check for problems with your system files. Hope this helps
Clean install of windows (Delete all partitions and re install fresh) would be the easiest way to fix the driver problem. I did also find this article on how to manually install the usb driver. Best of luck http://support.microsoft.com/kb/329632
Need recovery disc for compaq presario SR1920NX
go to http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&dlc=en&product=3184154
If you don't want to purchase the recovery disks you may want to just install a 'generic' windows xp, Vista, or Windows 7 and download the drivers you need (if not included in the generic installation) and install the computer's unique drivers.
My smartbro hsdpa mf627 won't install correctyl in windows 7 computer it requires drivers which i don't have
first you have to download the windows 7 driver for the smartbro hsdpa mf627. since you can't download it in you pc cause you can't connect to the net because it isn't installed properly. You have to download it on other computer perhaps if you have a friend who have a pc with internet connection ask for him a favor for you to download the driver if he will help download it and save it on a USB flash disc and installed it in you laptop...Hope it helps you
3answers
I cannot download the driver of my printer hp deskjet 930c i'm using ms windows 7 can you help me to fix my problem?
Hi, How are you installing the drivers, is it from the website or from the Disc that came with the printer? You can download an update on windows that contains the drivers for the printer. Here is the link. download and install it, then try to add the printer : look at the picture below:
redmatrix_0.png You don't need to click on the windows update anymore.
Thank you for using Fixya.
Wireless does not function on my toshiba laptop, L300 what do I do?
First of all, make sure your wireless device is powered on.
Then if problem continues, go to Control Pane->Device Manager and make sure your wireless device is installed correctly. the wireless device mustn't have any notification icon(yellow, red). For example in this image wireless device is installed correctly
If your device has a yellow icon that means your device isn't installed correctly. You need to reinstall wireless driver. If you have drivers CD install drivers from it. If you don't have CD, You can download driver from the following link:
If your OS is windows 7 click here If your OS is windows xp click here If your OS is windows vista windows 7 driver will work. So download windows 7 driver.
After you download unzip package and launch installer. Follow installation instructions, restart your pc and you are done.
Thank you for choosing FixYa.
6helpful
Windows 7 i need audio drive Problem with the IBM ThinkCentre S50 8183 - P4 3 GHz PC Desktop
OK. download it from this link:
http://download.cnet.com/Realtek-AC-97-Driver-Windows-Vista-Windows-7/3000-2120_4-10962344.html
please Vote
Top Rio Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
ADMIN Andrew
ADMIN Andrew
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
