AEG SANTO 75438 DT
SOURCE: AEG Santo Fridge light flashing
Here is fix photos:
http://www.elisanet.fi/mtj/santo/AEG-Santo-fix.html
SOURCE: can I buy spare shelves
MAYBE,GO TO SEARS .COM CLICK ON PARTS PUT IN YOUR MODEL NUMBER AND SEE IF THEY HAVE YOUR PART,ALSO TRY REPAIR CLINIC.COM-MIKE
SOURCE: AEG Santo fridge not cooling but freezer is working.
The compressor is obviously still good or the freezer wouldn't work.I'm sure you checked the settings,but turn the freezer all the way up (hot)after it is cool so the unit doesn't come on for the freezer,then turn the refrigerator controls all the way down to the coolest setting.listen for the compressor to start,and/or the fans to run.If the compressor starts,and no fan there may be a problem with the fan.(this is a general test I'm not familiar with your specific unit which may not have a fan,but most newer units do).If the compressor doesn't start after a short time the thermostat/control for the refrigerator section is broken,and needs replaced.
SOURCE: No ice in the ice dispenser since yesterday
the trouble is coming from eithier the micron switch located at the backof the paddle,or the auger motor.It is the motor that rotates when you press the cube dispenser lever located at the back portion of the icebucket,it might got stucked.or its winding is open Try to hve a check ,first open the freezer door, pull out the icebucket, look fr the light switch then maintain the door open,use your right hand in pressing the switch to simulate a closed door position,next use your left hand to press the cube dispenser lever, if the auger motor rotates and you heard a humming sound, it means it is only your ice cubes that sticked together preventing the motor to rotate freely,or there is something wrong with your bucket only,if your hear humming sound only, the auger motor is stuck up, unplug the unit, removed all the screws securing the bracket,disconnect the wiring connector, pull out it out,try to thaw the froozen motor if it is still stuck,wait a longer more or try to apply wd40 oil in between the entangled rotor and core, lubricte.If you hear nothing the winding might be open or there is no supply to the motor., point of check- micron switch- check for continuity,wiring leading to it and the line goin out to cabinet/inside, check the main connector to the bucket area for corrosion or accumulated dirts, And lastly if you are not confident enough to do the job sir better to calla qualified technican to do the troubleshooting sir, safety is our first priority.
SOURCE: AEG SANTO No_frost refrigerator beeps with 5 sec freqency
We have the same fridge, and I could not find my model either!
The label is hidden on the bottom of the top part on the left side, you need to take the veggie tray out to see it. I spent about 3 hours finding the model on the net, and in the manual it said where to look lol.
This mysterious model is the AEG SANTOS 3895-6 KG AKA S3895-6 KG productnumber 928405123-- last two digits can be 00-33.
We had the same problem, solution: press and hold the ON button for minimum of 3 seconds. The fridge switches off. Wait 10 seconds and repress the same button. That´s the quick fix.
To make it go away completely switch off fridge, pull out plug, and thoroughly clean the air vents on the back below using compressed air. After this the problem went away permanently.
Good practice to airclean every 6 or 7 months. You can find the manual for the S3895-6 KG on http://www.electrolux-ui.com:8080
