SOURCE: my Canon printer ip4000 power button keep flashing
It may indicate a printhead error. Look at the followng instructions at the Canon website:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=10239
SOURCE: My canon ip4000 5 yellow flashes with 1 green
Search Results for ORANGE 5 AND GREEN 1
<<Previous 30
results Next>>
1.
Power
light (or Alarm and Power lights) alternate(s) between orange and green
After long green flash, there are 2
or more alternating orange and green flashes. There may also be a Service Error
message on the computer screen.
2.
Alarm
/ Power light flashes orange 11 times consecutively (Automatic Print Head
Alignment Error)
3.
Alarm
/ Power light flashes orange 2 times consecutively (Load Paper / Paper Feed
Error)
4.
Alarm
/ Power light flashes orange 3 times consecutively (Paper Jam Error / Cover
Error)
5.
Alarm
/ Power light flashes orange 4 times consecutively (Out of Ink Error)
6.
Alarm
/ Power light flashes orange 5 times consecutively (Print Head Error)
#1 & #6 seem to be as close as I can find:
here is the page (Below) if you just put the error in the space provided.
SOURCE: The printer flashes orange light five times, and green once
Probably your waste ink counter. Should be cleaned or replaced before
resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
SOURCE: 3 yellow flashes, then 1 green on a Canon PIXMA
3 flashes is a GREAT symptom report. We need some more than that, but it does give us a direction.
If this is a "Service Call Error", it will be accompanied by an on screen message that includes a "6000" error code.
Here are the possible solutions....
- Timing sensor unit (QM2-1213)
- Timing **** disk film (QC1-4833)
- Feed roller ***'y (QL2-0598)
- Platen unit (QM2-1215)
- Logic board ***'y (QM2-1548)*1
- PAPER FEED MOTOR (QK1-0550)
These solutions are not for the novice, but are user servicible for many out there.
If this is a "Operator Call Error", it will also be accompanied by on screen error codes
Paper jam. [1300]
Paper jam in the under guide. [1304]
Paper jam in the rear guide. [1303]
Solution: Remove the jammed paper, and press the Resume/Cancel
button.
OR
Front door closed. [1250] Open the paper output tray.
Get a free copy of the service manual by contacting me at www.Equipmentcity.net
SOURCE: light flashing green and yellow will not print
Hi this is only a try it may work
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
