Fogel FOG-CR67PCUS Sliding Glass Door Merchandiser 67 cuft Logo
bats Posted on Jun 22, 2012
How to adjust the thermostat - Fogel FOG-CR67PCUS Sliding Glass Door Merchandiser 67 cuft
1helpful
2answers
My forced air heater in the bathroom keeps going on and off when it reaches the set degree. Is the heater the problem or the thermostat.
Try setting the Thermostat to the highest temp and see if it keeps running. If temp goes to the max it is the Thermostat if it stops prior to the thermostat setting it is the heater!
1helpful
How do you adjust the oven flame on a eruomaid gas oven model gg90s thanks
Most gas ovens have the flame regulated by the oven thermostat. It may be adjustable down the centre of the thermostat shaft but a lot of newer ovens are not adjustable anymore. You may need a new thermostat if the oven isn't getting hot enough.
Adjusting the thermostat for best temperature
There is a adjusting screw on the thermostat. So your not guessing you should heat it on a. Bench with a amp meter on the line . Then check temp and adjust from there. The factory thermostats are. Preset . If you installed the correct one adjustment should not be necessary? Is the element tight on the bottom?
Tech manual
Most Jet-Tech dishwashers has one adjustable rinse thermostat and one fixed wash thermostat. The wash thermostat can be substituted with an adjustable thermostat. Location depends on the model. F-18 are located on top. F-22 are located under next to the wash tank. Search by part number or description
My themorsat stop working,and I replaced the batteries.
see this causes and fix it. God bless you
Furnace Produces No Heat Possible Causes
Possible Repairs
  • Remove cover of thermostat and loosen screws holding unit to wall. Level the thermostat. Re-tighten screws and replace cover.
  • To adjust the heat anticipator, please see Heat Anticipator Adjustment.
  • Furnace Turns On and Off Frequently ("short cycling")Possible Causes
  • Dirty thermostat components
  • Heat anticipator not set correctly.
Possible Repairs
2helpful
3answers
How to adjust temperature
Hi, Please use your thermostat to adjust your temperature setting. Most refrigerator thermostat is come with actual temperature setting at thermostat dial but it just use range : cold-medium-off ( or 5...5..3....1..0). So for instance to get your refrigerator colder just set between medium - cold. If your thermostat defective , your refrigerator will work unpredictably. In this case you need to fix or replace the thermostat.
Regards, Jay
Frosting up of the freezer. The fridge seems not to turn off
adjust the thermostat setting if digital type thermostat adjust it by pressing upward if your thermostat analog type rotate it counter clockwise then observe operation of thermostat. or replace thermostat maybe it is already damage.
1helpful
Temperature setting is wrong. Stove is about 80 deggrees cooler than what the knob is set at. I am a yooper too.
If you think it is too cool, adjust the thermostat to make it hotter.
To Adjust the Thermostat:
1. Put the Oven Set knob in the OFF position.
2. Press and hold the HOUR INCREASE and the HOUR DECREASE pads at the same time for 5 seconds until the display changes.
3. Immediately, before display changes back, press the HOUR INCREASE or DECREASE pads to increase or decrease the temperature in 5 degree increments.The oven temperature can be increased up to 35°F.hotter or decreased 35°F. cooler.
If the oven adjustment is set cooler than the factory setting a minus sign “–” and the new temperature will appear in the display.
4. Wait several seconds for the control to automatically set and return to its previous setting.
NOTE: This adjustment will not affect the broiling or the self-cleaning temperatures. The adjustment will be retained in memory after a power failure.
To Adjust the Temperature on Models with Only an Oven Set Knob
1. Put the knob in the OFF position.
2. Pull the knob off by pulling straight out.
3. Press and hold the HOTTER or COOLER button for 5 seconds to make the oven 20°F. hotter or 20°F. cooler.
When you are adjusting the thermostat, the following lights will flash indicating where the thermostat will be set when you release the
adjustment button:
OVEN ON indicates the thermostat will be set at the factory setting.
PREHEATED indicates the thermostat will be set 20°F. hotter.
CLEAN indicates the thermostat will be set 20°F. cooler.
4. After you have made the adjustment, replace the knob.
If you have any doubt please go through the manual which is given here
http://kitchen.manualsonline.com/manuals/mfg/hotpoint/rgb745.html
Hope this will help you
Thank you
Temp 50 degree too cold need to adjust thermostat on JGRS14
ive installed 100 new thermostats over the years and they are set from the factory.no adjusting.now some knobs have an adjustment on them.and some times customers got knobs mixed up and got the wrong one one there.
Top Fogel Refrigerators Experts
ZJ Limited
ZJ Limited
john h
Are you a Fogel Refrigerator Expert? Answer questions, earn points and help others
