I changed the thermostat and its not popping all the corn in the kettle
There is a adjusting screw on the thermostat. So your not guessing you should heat it on a. Bench with a amp meter on the line . Then check temp and adjust from there. The factory thermostats are. Preset . If you installed the correct one adjustment should not be necessary? Is the element tight on the bottom?
