Question about Jet Tech Systems Dishwashers
Tech manual How do you adjust the wash and rinse tempartures
Robert Marsolais
    Problem Solver:
  • 25 Answers
Most Jet-Tech dishwashers has one adjustable rinse thermostat and one fixed wash thermostat. The wash thermostat can be substituted with an adjustable thermostat. Location depends on the model. F-18 are located on top. F-22 are located under next to the wash tank. Search by part number or description
Posted on Jul 15, 2014
Hobart dish machine. We were told by Ecolab tech that we need to rinse off all presoak, soaps and sanitizers before passing through the maching as they cause foaming/excess suds. I do not find that info...
That's true. excess of foam can cause poor wash pressure and poor final rinse.
Operation manual , pag.24. (F17791Rv02-06.pdf)
DO NOT exceed chemical manufacturer's recommended concentrations for detergent, sanitizer, rinse aid or lime scale remover.
Mar 13, 2015 | Hobart Dishwashers
Hi, my Zanussi zdf511 doesnt seem to be adding any rinse aid on any of the rinse aid settings?
Rinse aid dispenser can receive a maximum level of 140 ml rinse agent. Consumption rinse agent could be per wash cycle of 2 to 7 ml depending on the settings.
Thus 140 ml is enough for 20-70 wash cycles, depending on the degree of adjustment.
Dado
Dec 02, 2014 | Electrolux Genuine ZANUSSI ZDF511...
Users manual for admiral atw4475xq
ATW4475XQ - Admirial Water Saver washer - Adjust Rinse cycle water level
The rinse cycle water level can be adjusted. Unplug the machines power.
You can youtube a video on how to remove the top control panel, its just 2 screws on the back of it,
phillips head. Swing the control panel up, and find something to support it so you have both hands free.
(http://www.youtube.com/watch?v=MYn0_qCFdec)
You'll see a clear plastic tube coming up from the back rear like 3/8 in diameter, to a "T"
connection. The one that goes to the left, thats the wash water level switch it connects to. The one you
can adjust, large, medium, small, from the front of the panel . The other off the T goes to the rinse
water level switch. There is not a knob to adjust it. But if you look at the bottom of the lever
mechanism/cam pickups of both switchs, you will see that they are the same. Rotate the wash load size
(knob on outside of control panel) from small to large, back to small, notice how the mechanism changes?
The rinse water level swtich acts the same way, although it is only a 2 position switch, small and
large. Once you watch the wash level mechanism move from rotating it back and forth a few times, you
should be able to see how to rotate that same mechanism on the rinse switch 1 click. It will click into
place, there are only 2 positions as I said and from the factory its in small, so once it "clicks in"
dont go any further. I did mine with a very small screw driver without removing the rinse switch.
Once you get that hidden switch turned to the other position, put it back together, fire it up and now
your rinse is the large level, all the time.
NOTE: There is a white plunger out of the end of each switch with a screw located in place. Dont mess
with the screw or that plunger. As you adjust the lever mechanism/cam this adjusts the amount of that
plunger sticking out, which changes the pressure pickup for water level.
May 17, 2012 | Admiral Washing Machines
I have an admiral washer atw4475xq can you adjust the water level on the rinse cycle
Pulled this together from a couple of Solutions & added some helpful tips I found as I successfully changed the rinse cycle water level!
Nov 14, 2011 | Admiral AW22 Top Load Washer
Front load kenmore will not spin at end of wash
I have to know a little more detail before I can give you a reasonable solution. Does the washer drum fail to spin period? In other words, if you select rinse cycle manually, after the rinse cycle completes, does it fail to spin? Also, please give me the model number so I can look it up on my tech site. Thx Rick
Oct 06, 2011 | Kenmore HE2 Plus Front Load Washer
The wash rinse temp stays on warm cold will not let me change temperature
rinse temp are fixed on most machines check you manual if yours are adjustable
Jun 12, 2011 | Washing Machines
Paykel fisher wash problem
its possible, depending on problem with unit, if youd like you can acess a tech sheet behind the console,theres a pretty good desription of common troubles encountered and fix it solutions.
Feb 27, 2008 | Fisher and Paykel GWL11 Top Load Washer
Dishwasher
Check to see if you have any switches on your dishwasher that could by pass a rinse cycle. Use a hotter temparture when washing, Check your water level,check your filters on your inlet hose top and bottom. When it gets to a rinse cycle you should hear it drain out and bring in fresh water. you could change to a liquid detergent. Dont over load your dishwasher. make sure you are using rinse aid and try adjusting it up one setting. Shiney glasses means your rinse add is working. NZL
Jan 04, 2007 | Kenmore 18 in. 14432 / 14439 Built-in...
Dishwashers Logo
165 people viewed this question
Top Jet Tech Systems Dishwashers Experts
Colin Stickland
Colin Stickland
ray gallant
Are you a Jet Tech Systems Dishwasher Expert? Answer questions, earn points and help others
