SOURCE: MDS-JE480 MiniDisc Deck
The problem with the TOC reading and then appearing C13 is a problem with bad electrical contacts.
Remove the connection to the mains outlet, remove the top cover (5screws) and the remove the 2 paper flatcables that connect the main PCB and the disk unit on both sides. Plug them back in and possible your problem is solved.
A better solution is, of coarse, to replace both cables by new ones, as the quality is rather bad, and once disconnected, they should be replaced.
Good luck!!!
1000 soluciones
SOURCE: Can i transfer music from MP3 player to minidisc?????
Hi, I would like to transfer music from my Ipod to a minni disc is this possible??, Maurice.
SOURCE: Hi every time I load a minidisc into my MDS-JE480
The error means that the player is unable to read the table of contents (TOC) on discs any more.If it's an occasional error then you can try switching to TDK blanks as they seem to be easier for flaky players to read, but if it's happening regularly to all discs then your machine is unrepairable due to a total lack of spare parts.
On the plus side, there are millions of MD units now lying unused as folks have moved on from them and as they're mostly worthless people don't generally bother with trying to sell them. Almost every piece of MD gear I own has come free of charge via my local FreeCycle and Freegle groups. Whatever you do, don't buy a used player from anyone: they're all getting on now and the TOC error is an age-related fault which may occur at any time.
If you wish to see exactly what features other machines have then visit the superb equipment browser at minidisc.org. The site is hosted but n longer maintained though so some information is out of date, but it's still the most comprehensive source of free information about MD available.
Sorry here's probably no hope for your MDS-JE480, but I hope that my reply has given you a practical alternative means of solving your problem.
