SONY MDS JE 530. (C14) Toc error.
I could play music there is on my MD's, but if I Erase them and record new music on them, they wont play it, and when i eject the MD and put it in again I got the message (C14) TOC ERROR, what's wrong ? Could MD's be to old to record on ?
  • 1 more comment
  • Anonymous Apr 01, 2013
    I'll find a way to another solutions of this problem, I do as i would made a recording, but let my MDS deck stand on paused recording, and connect my MD walkman with the IR Cable, and made the recording there instead :)
  • Anonymous Apr 03, 2013
    I guess it could be the disc, because when I put it into my MD walkman I also got an error message. Thats why I think the Discs could be too old to rewrite...
  • Eliezer Pennywhistler
    Eliezer Pennywhistler Apr 03, 2013
    Minidiscs don't get "too old". They work 1,000,000 times (literally). But now we know it was the disc and not your laser, as so many people wrote you. Like your owner's manual tells you, it is a TOC problem on the disc. Try putting it in a machine and do "ERASE ALL". 99 times out of 100 that will fix the disc. You will lose the contents, though.
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 236 Answers
Your owners manual (you DID read your owners manual, right?) says the machine cannot read the TOC on the disc.
It might be a disc problem and it might be a deck problem?
Have you tried a different minidisc?
Have you changed any of the SET-UP settings? Take a look at them, too.
Posted on Apr 03, 2013
5 Related Answers
Anonymous
  • 87 Answers
SOURCE: Sony MDS JE-320 not recording
This is a common problem with the overwrite head on these units. There is a two wire connection going to it which fails after a couple of years of service. Or for some reason the overwrite head does not make contact to the MD disk surface, it is suppose to when recoding or writing the TOC.
This overwrite head assembly is very very delicate, provided you feel comfortable to work on it you can probably fix it. Or find a local electronics technician to help you with that.
Do some reading on the Minidisc Forum
Hope this helps
Posted on Jan 11, 2009
TOLhamRadio
John
  • 509 Answers
SOURCE: Kenwood MD plays ok but recordings fail to play; U TOC error?
Without a decent Table Of Contents, your MiniDisc will NOT work, as you've found out. Does it matter what brand of MD you use? I would record it at "1X" and NOT 4x speed too. Try erasing a blank minidisc first and then shut off the unit and then turn it back on and see if the TOC works. Try adding a title, then turn it off and back on. Then try the CD to MD.
Posted on May 27, 2010
Anonymous
  • 192 Answers
SOURCE: i have Sony md player/recorder,model is MDS-E10.
Minidisk systems encode music diffferently than CD's do. The instruction manual for your model can be found at http://www.minidisc.org/sony_mdse10_manual.pdf you will need to reference page 18 for instructions and trouble shooting.
Posted on Jun 02, 2010
Anonymous
  • 7191 Answers
SOURCE: the problem is I require a instruction manual for
You can download and print the instruction manual in PDF format by clicking this link. '
http://www.docs.sony.com/release/MDSJE530.PDF
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Posted on Feb 15, 2011
eliezerpenny
  • 236 Answers
SOURCE: Hi iown a sony- mds je 330, how can i transfer from md to computer?
Sony has a free program called Sonic Solutions. It stinks to high hell. But it is free.
I strongly suggest you either play the MDs into your computer via the LINE IN, or buy a Behringer UCA202 USB Audio Interface from Amazon for $30 and input the audio digitally via the USB.
That's how I do it.
Posted on Oct 03, 2012
2answers
My MDS-E10 Has Been Having Problems Lately. I Own Hundreds Of Mini Discs That I Have Recorded Music On Several Years Ago. Everything That I Have Recorded On These Mini Discs (Years Ago) Play Fine With No...
hi there is nothing to do by yourself. you need to take your md player to the next authorized service. seems the optical device that reads the discs has worn out, compareable to turntables you need to change the `needle` ;)
You may well be right. Try a different brand of disc.
JE530 c13
1) It's more likely your laser died than the the drive failed.
2) Run back to your repair guy, and when they fix it (IF they fix it), ask to see it work before you go home. They damned well better fix it for free!
3) Buy another one on eBay.
C13 means the machine cannot read the TOC on the disc. It is possible you have a disc with a bad TOC. You may have left it near a magnetic field, such as a speaker or a component transformer. Try another disc. Or take a disc and erase it, then record on it. See what happens.
That's how I do it.
My sony md player wont read HI mini discs
The 480 is not designed to read HI MDs. If I remember right, it can read them as regular discs.
You can always purchase a HI-MD recorder, if that is important to you.
Is there any other remote that will work with Sony Mini Disc Player & recorder model mds je-320
Most Sony MD remotes will operate most functions on this unit, almost all of the Sony MD remotes are available on ebay even the rare ones.
2helpful
Sony minidisc MDS-JE530 c13 rec error
This could be a solution for your problem, if you get a C13 error it's because of dust on the lens causing TOC read errors. Try blowing out dust using clean compressed air (the kind in the can used for computer maintenance).
Cd wont play after finalize an toc error C14 appears
You can visit this link to check it this error out.
toc error C14
Best regards.
1helpful
Jb 940 md player. Recording a full disc, always results in playback stopping around 38 mins. previously recorded discs will play back ok, so suspect record process not completing. When played in spare...
When you get done recording, do you wait until the "TOC" light stops flashing? If you cut off power before the Table Of Contents is written, then it can't find all your music. Even if you eject, it should still flash a little red TOC or UPDATE before it spits the disc out. Check for that. okay?
Hope this helps
Marvin
Marvin
