Sony MDS-JE330 Mini Disc Player Logo
Question about Sony MDS-JE330 Mini Disc Player
SONY MDS JE 530. (C14) Toc error.
I could play music there is on my MD's, but if I Erase them and record new music on them, they wont play it, and when i eject the MD and put it in again I got the message (C14) TOC ERROR, what's wrong ? Could MD's be to old to record on ?
  • Sid Smith Mar 17, 2018
    Hi, ok.....so I'm 5 years too late in this thread, I doubt you're still here?!! I recently picked up a Sony MDS-JE530 from my local freecycle, plugged it in when I got home and shoved in a disc, it showed up TOC ERROR C13, whatever disc I tried. So (after switching unit off and unplugging!), I removed the top cover, pulled the ribbon cable ends, and cleaned them with a cotton bud using Isopropyl Alcohol, this was just hoping as far as I was concerned. Anyway, I reconnected the ribbons, top cover back on, plugged the unit in and switched on, shoved a disc in, and BINGO!!! I have been using it every day, and all function are working flawlessly! So whatever fault code shows up, it could be as simple as a bad connection, as in my case. It's simple enough to do, and only takes a few minutes, it's well worth trying as a first call.
Eliezer Pennywhistler
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 236 Answers
You may well be right. Try a different brand of disc.
Posted on Nov 25, 2014
3 Related Answers
Anonymous
  • 192 Answers
SOURCE: i have Sony md player/recorder,model is MDS-E10.
Minidisk systems encode music diffferently than CD's do. The instruction manual for your model can be found at http://www.minidisc.org/sony_mdse10_manual.pdf you will need to reference page 18 for instructions and trouble shooting.
Posted on Jun 02, 2010
Anonymous
  • 7191 Answers
SOURCE: the problem is I require a instruction manual for
You can download and print the instruction manual in PDF format by clicking this link. '
http://www.docs.sony.com/release/MDSJE530.PDF
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Posted on Feb 15, 2011
eliezerpenny
  • 236 Answers
SOURCE: Hi iown a sony- mds je 330, how can i transfer from md to computer?
Sony has a free program called Sonic Solutions. It stinks to high hell. But it is free.
I strongly suggest you either play the MDs into your computer via the LINE IN, or buy a Behringer UCA202 USB Audio Interface from Amazon for $30 and input the audio digitally via the USB.
That's how I do it.
Posted on Oct 03, 2012
2answers
My MDS-E10 Has Been Having Problems Lately. I Own Hundreds Of Mini Discs That I Have Recorded Music On Several Years Ago. Everything That I Have Recorded On These Mini Discs (Years Ago) Play Fine With No...
hi there is nothing to do by yourself. you need to take your md player to the next authorized service. seems the optical device that reads the discs has worn out, compareable to turntables you need to change the `needle` ;)
Your owners manual (you DID read your owners manual, right?) says the machine cannot read the TOC on the disc.
It might be a disc problem and it might be a deck problem?
Have you tried a different minidisc?
Have you changed any of the SET-UP settings? Take a look at them, too.
JE530 c13
1) It's more likely your laser died than the the drive failed.
2) Run back to your repair guy, and when they fix it (IF they fix it), ask to see it work before you go home. They damned well better fix it for free!
3) Buy another one on eBay.
C13 means the machine cannot read the TOC on the disc. It is possible you have a disc with a bad TOC. You may have left it near a magnetic field, such as a speaker or a component transformer. Try another disc. Or take a disc and erase it, then record on it. See what happens.
That's how I do it.
My sony md player wont read HI mini discs
The 480 is not designed to read HI MDs. If I remember right, it can read them as regular discs.
You can always purchase a HI-MD recorder, if that is important to you.
Is there any other remote that will work with Sony Mini Disc Player & recorder model mds je-320
Most Sony MD remotes will operate most functions on this unit, almost all of the Sony MD remotes are available on ebay even the rare ones.
2helpful
Sony minidisc MDS-JE530 c13 rec error
This could be a solution for your problem, if you get a C13 error it's because of dust on the lens causing TOC read errors. Try blowing out dust using clean compressed air (the kind in the can used for computer maintenance).
Cd wont play after finalize an toc error C14 appears
You can visit this link to check it this error out.
toc error C14
Best regards.
1helpful
Jb 940 md player. Recording a full disc, always results in playback stopping around 38 mins. previously recorded discs will play back ok, so suspect record process not completing. When played in spare...
When you get done recording, do you wait until the "TOC" light stops flashing? If you cut off power before the Table Of Contents is written, then it can't find all your music. Even if you eject, it should still flash a little red TOC or UPDATE before it spits the disc out. Check for that. okay?
Sony MDS JE-320 not recording
This is a common problem with the overwrite head on these units. There is a two wire connection going to it which fails after a couple of years of service. Or for some reason the overwrite head does not make contact to the MD disk surface, it is suppose to when recoding or writing the TOC.
This overwrite head assembly is very very delicate, provided you feel comfortable to work on it you can probably fix it. Or find a local electronics technician to help you with that.
Do some reading on the Minidisc Forum
Hope this helps
Top Sony Audio Players & Recorders Experts
Marvin
Marvin
Morne Olivier
Morne Olivier
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
