Service Manual for the Electrolux RM4400 Fridge/Freezer
SOURCE: Cannot reverse door on Electrolux fridge freezer
Basically they needed to supply an additional door mount for the left hand side of the door as well as the right hand side. Problem now sorted. Poor instructions in the manual didn't help here!
SOURCE: how to recharge freezer electrolux FFH17FC7CW0
HI, It is a big job to recharge a unit. If it need recharged, it means there is a leak. Do you have any cooling at all? If this a self defrosting freezer? If it is self defrosting, make sure there isn't any frost building up on the evaporator panel.
Vic
SOURCE: Freezer ok, fridge not cold
Often you can unplug it overnight and it'll melt out, correcting the problem for some time. The electric element might be burned out, although I'd suspect the defrost timer. It's usually located behind the unit, near the bottom. Often all you will see is a 3/4" hole in the back plate with a flat screwdriver slot. Turn it (only turns one direction) with a flat screwdriver, and all will work fine for some time (usually). If not, standard procedure is to replace the defrost timer assembly, as the clock motor has likely gummed up. Maybe available at http://www.repairclinic.com, or a local appliance repair shop. They're often generic, as in not specialty oem specific.
SOURCE: american fridge freezer siemens KA58NA50GB. Freezer not freezing
If you are not capable to do that much better to call service Engineer to avoid big damage of your Freezer.
SOURCE: Electrolux fridge freezer, Motor never turns off.
dear sir/madam
i think this is thermostat setting problem please make sure freezer,s thermostat nobe (nidle) is in correct position .then see thermostat temperature settings . may be thermostat is not controlling to compressor motor that why it,s running continuously.
hope answer the question,
thank you
please vote!
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
I don't recognize this model for this manufacturer. You can always go to their site www.ElectroluxAppliances.com or their sister site, www.Frigidaire.com, and download manuals based upon model numbers under Product Support.
