Question about Electrolux 3.53 cu. ft. / 100 liter Upright Freezer EUU6174
Exclaimation triangle red light is on - Electrolux CUU6174
The freezer - exclaimation triangle red light is lit and the temperature is not changing. The freezer has been thawed and has been witched on and off numerous times and the ducts have been cleaned. Is there a reason why the red light is showing?
Posted by bina_parmar on
Raz Mataz
  • 389 Answers
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Posted on Apr 21, 2010
I defrosted my Electrolux intuition chest freezer yesterday and the red warning triangle on the lid won't stop flashing now. Why?
Check the temperature inside the freezer, chances are it just is letting you know it hasn't reached the correct temperature yet.
Aug 11, 2016 | Electrolux Freezers
Re lights lit on freezer
Red light lit on freezer means that is not reaches operating temperature.
Most often the old freezer has three indicator lights.
- Green light : that it is brought to a power source and turned on - Red light : means that the temperature is above -18 degrees
- orange light : pressing the so-called SUPER-switch which means that the compressor is running continuously. The SUPER-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual.
In new freezer managed by the electronics, this function has a predetermined maximum duration, in order to protect the compressor, and can have different marketing names like "shopping".....
Dado
Sep 02, 2014 | Electrolux Freezers
What does the red warning light by the triangle mean on a blomberg
Under normal operating conditions, the internal
temperature of the freezer will ensure the longterm
conservation of the stored food.
When such temperature rises above a certain
level (-12 °C), the appliance will trigger an
acoustic and light alarm. The light alarm is a
blink red light (Red Alarm Indicator Light), while
the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing
the Acoustic Signal Stop Switch once.
When switching on the freezer for the first
time, the Red Alarm Indicator Light will
blink until the internal temperature has reached
a level required for the safe conservation of frozen
food.
Dado
May 28, 2014 | Zanussi 10.31 cu. ft. / 292 liter Chest...
What do the red light with abell shape which is lit up mean on my 18 year old tricity bendix freezer mean
It's a temperature warning that the freezer is no longer at the correct temperature. Check all is clean and working, door seal intact etc. If short of gas, probably time to get a new one!!! Bet it won't last 18 years this time though!
May 01, 2014 | Freezers
Red light showing high tempature
cooling temperature of freezing is damaged and also damaged heater machine which keep in deep freeze but controller point keep in normal side,you must be repair that problem as soon as possible otherwise full freezing system get damaged.
Mar 22, 2013 | Frigidaire Freezers
Frigidaire freezer CHEST FC263C USER manual. a red light is showing
http://manuals.frigidaire.com/prodinfo_pdf/StCloud/297079200en.pdf
Page 5 explains that the "Red" light is lit until temperature is reached.
Mar 06, 2011 | Frigidaire FFN15M5H Chest Freezer
Electrolux 3.53 cu. ft. / 100 liter Upright Freezer EUU6174 Logo
1,483 people viewed this question
Top Electrolux Freezers Experts
Dennis Boxerman
washington munene
Level 1 Expert
ray gallant
Are you an Electrolux Freezer Expert? Answer questions, earn points and help others
