Question about Electrolux Freezers
Https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help
Use this link for future/current reference
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Posted on Dec 17, 2017
SOURCE: Hotpoint Mistral frost free fridge freezer.
This is a little hard for me to understand being a yank and all. 0C is 32 Fahrenheit, right so 4/5 is about 40? make sure everything is working, compressor , evaporator fan motor (the one inside) condenser fan motor (the one outside) if you have one. You should have an adjustment for freezer and one for the fridge sections, right. The fridge section controls what amount of cold air comes from the freezer compartment. Check the vents inside, make sure they are not blocked and they open and close when you adjust the control. If this all checks good then check the thermostat. If the compressor shuts off prematurely, then a new thermostat may be in order. If you think you can do this, find the thermostat, by-pass the wires. this will make the compressor run continuously. After 20 minutes or so it should make the desired temperature or close to it. None of the fans or compressor should turn off while this is by-passed.
Posted on Dec 31, 2007
SOURCE: FREEZER SECTION WORKING OK, FRIDGE SECTION NOT WORKING
Check the vents of your fridge side if present, if no air then may be your blower not working or some ice formation that blocks the air(try defrosting). Check also your vents for obstruction or overloaded with stocks.
Posted on Jan 26, 2008
SOURCE: amana 25. cu ft..freezer not working...making rattling noise now and then
Check the defrost timer, rotate it until a solid click is heard. If your unit starts to work replace that timer. Good Luck
Posted on Aug 05, 2008
SOURCE: samsung cool n cool freezer & refrigerator does not cool
samsung refrigerator won't cool how do we fix it?
Posted on Sep 06, 2009
SOURCE: zanussi fridge freezer not cooling
no, its probably weak capacitors which provide power to switch the relay. Take the control board out and ask a friendly TV repair tech to change the capacitors
Posted on Oct 06, 2009
Testimonial: "Thanks it fixed the problem"
Jul 03, 2016 | Electrolux ICON Professional E32AR75JPS...
Jun 05, 2015 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Jan 11, 2015 | Electrolux Frigidaire Freezer Bottom...
Oct 06, 2014 | Engel Freezer 22 Qt. Fridge/Freezer
Jul 15, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Mar 07, 2010 | Electrolux Freezers
Sep 15, 2009 | Freezers
Aug 07, 2009 | Freezers
Nov 27, 2008 | Zanussi Freezers
Sep 30, 2007 | Freezers
232 people viewed this question
