You have a bad water valve. you can replace the valve and it will be fine. I will warn you that working on your machine can be complicated. after you look closely at the how, you may decide that a pro is the best way to go. here is a link if you decide to tackle it yourself.http://www.partselect.com/ModelFrames.aspx?ModelID=467904&ModelNum=WPGT9360E0PL&mfgModelNum=&ManufactureID=2&Selected=00117836i01&Position=2&mfg=GE&Type=&Mark=2
SOURCE: Ge Profile Harmony Washer doesn't drain properly.
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
SOURCE: GE Profile Prodigy filled with water & won't start
If you don't hear a click when you close the lid, replace the lid switch.
SOURCE: washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
SOURCE: GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
SOURCE: GE Profile Washer leaking underneath during spin cycle
its your outer tub it has a hole in it
