20 Most Recent GE Spacemaker WSLP1100D Top Load Washer Questions & Answers
2answers
GE GSLS1100 Spacemaker won't spin
Solved: There was a piece of fabric caught in the water drain pump. Opened the cap at the back bottom right of the washer and pulled it out. Worked fine after that.
10/28/2019 11:13:00 PM • GE Spacemaker... • Answered on Oct 28, 2019
Washer won't drain!
Sounds as the pump has gone wrong, if it's turning & doing the usual cycle except for draining the motor is fine, check the pump filter trap to be sure there is no obstructions as a simple penny can stop the pump motor turning preventing the machine from draining, I hope this helps.
1/24/2018 8:36:44 PM • GE Spacemaker... • Answered on Jan 24, 2018
0answers
Bleach spots
Be the first to answer 11/24/2017 7:54:03 AM • GE Spacemaker... • Posted on Nov 24, 2017Be the first to answer
Washer constantly draining after first cycle
For the machine to keep filling it would indicate that there is a siphoning problem. Check the outlet hose is not running along the ground, it has to rise up then loop back down or the water will just run straight down the drain. If the problem only happens after the first pump out it would indicate the end of the outlet hose is lower than the drum or there is no air break around the outlet hose. (The stand pipe should be larger in diameter than the hose from the machine). http://selfix-uk.co.uk/under%20sink%20plumbing.html
5/6/2017 12:39:29 PM • GE Spacemaker... • Answered on May 06, 2017
0answers
Where can i purchase replacement 10in. black corrigated G.E. washer drain hose
Probably generic drain hose at hardware, perhaps Ace.
12/22/2014 1:59:53 AM • GE Spacemaker... • Answered on Dec 22, 2014
How do I remove the agitator on my GE Spacemaker model GSLS1100?
Remove Pulsator (Blue) cap,Pulsator nut, Pulsator, and 2 washers and 1 nut. Pull up on the drum. But, 1st ask yourself WHY you want to remove the agitator!
7/2/2014 6:36:08 PM • GE Spacemaker... • Answered on Jul 02, 2014
2answers
Ge wslp1100a0ww washer leaves clothes soaking wet, not spinning properly
You don't say whether agitation is normal. Improper spin can be slipping V belt (stretched or cracked), part #WH01X10081, or loss of transmission fluid. Is there oil on the ground under the washer (shouldn't be)? Let's start here. Motor, belt, and transmission are at the bottom of the washer.
6/5/2014 5:18:04 PM • GE Spacemaker... • Answered on Jun 05, 2014
0answers
Code lo
Be the first to answer 3/23/2014 4:37:38 AM • GE Spacemaker... • Posted on Mar 23, 2014Be the first to answer
0answers
My GE Spacemaker wslp1100 top loader is draining very slow causing error code dr. I took black drainage hose off and it seems to be clean. Filters are clean inside washer. I want to know if a coin cou
You don't reveal full model number. It's not likely that a coin is blocking the water. The pump (part of the motor assembly) may be partially blocked inside or a garment (sock, u-shirt, etc.) may be blocking the water inlet to the pump. It's too early to remove the agitator.
12/19/2013 6:18:52 PM • GE Spacemaker... • Answered on Dec 19, 2013
GE Spacemaker WSLP1100D Top Load Washer Logo
119 questions posted
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
GE Washing Machines
  • GE Washing Machines
Most Popular Question
ge gsls1100 spacemaker spin
  • Washing Machines
