The only DVD'S for over 120 minuets I found was VERBATIN 8x 240 minuets---AND IT would not except>>said "unknown DVD"! I paid close to 20 bucks for 5 DVD'S---THAT DONT WORK! I have some old home movies I wanted to take off the VHS and put on a DVD. Can that be done? This JVC recorder was bought in 2010--not that old! It does fine in regular 120 minuets. What am I to do?
SOURCE: JVC DR-M100S
try recording on a re-writeable dvd i had exactly the same problem on a dr-m100 (the more primitive version of the dr-m100s) as follows: -- heard a distinct pop while recording -- after that, an error message indicating that i am trying to record on a write protected disk, even though i am not. recording on standard blank dvd now impossible. -- unit still plays dvd normally, except it takes twice as long to find beginning of program -- wierdly, it still records on re-writeable dvd's. the re-writeable dvd must be formatted correctly. the unit still formats re-writeable dvds normally
SOURCE: I have the JVC DR-MV5 VHS/DVD Recorder and I have
1 Dvd slider should be on DVD.
2. Press SET UP to access main menu
3.Press left and right arrow keys to select DVD SETUP then press down arrow
4. Press left and right arrow keys to select UTILITY
5. Use arrow keys to select FINALIZE
SOURCE: VHS won't work
Had the same problem on my JVC vcr/dvd combo unit.
You need to turn off the timer function. I did this by making sure my remote was in the "VHS" mode...turn the swith from TV to the right (found on the remote in the upper left corner...an then hit the "vcr" button. Then point the remote at the VCR unit and hit the No. 4 button (timer turns off). Your unit should not have the red timer displayed and you should be able to play your tapes okay.
Hope this helps.
SOURCE: I have a JVC DR-MV5S. When I dub a VHS to DVD,
The disk must be finalized. Instructions are on page 79 of the instruction booklet for the MV5S. I can't get the manual to download from the MVC site, but maybe it will work later. Hopefully you have the manual.
