20 Most Recent
JVC DR-MV7S DVD Recorder/VCR Questions & Answers
This can be due to a faulty LOADING drive settings, It can be due to a misalignment of the loading section and so the load does not reset to the PARK CONDITION of the MODE.
It can be a aulty gear, belt or jamming in the drive.
You need to open the player, remove the mechanism and manually check the forward and loading motion which can confirm. If the belt or the drive is jammed this can be checked and replaced or reset.
Check the mode switch settings of the forward loading.
JVC DR-MV7S DVD...
Answered
on Sep 19, 2011
There is a small capacitor on the power supply board, if memory serves me it is 220uf cap at 16 volts or higher, increase value to 470uf with a higher voltage rating. once the part is replaced the machine will function.
JVC DR-MV7S DVD...
Answered
on Apr 16, 2011
hi there
ok here i go male plug in the tv female plug in the vcr
from you cable box you have 3 cable 1 go tv room tv
two go two you vcr and 3 go to your room tv
if yo dont came right email me on
[email protected]
JVC DR-MV7S DVD...
Answered
on Dec 14, 2009
We have the same problem fiber optic unit need to be replace and cost more that what I pay for my machine thats that TRASH!!
JVC DR-MV7S DVD...
Answered
on Feb 21, 2009
It's not the outage that causes the issue, it is the power surge when it goes, often caused by a lightning strike of 100,000 volts, and also a surge when the power comes back on. If it took out one board, it took them all out, because they are all connected together.Change all the boards, but I bet it still won't work. Claim to your electricity utility company or claim on house insurance.
JVC Televison &...
Answered
on Mar 31, 2021
Visit the site linked above. It has circuit diagrams of many popular devices. You can get details there. Search the site by type in the "
brand name" of your device, in the "
Search box at the top right of the Homepage" to get gathered related posts.
JVC Televison &...
Answered
on Mar 18, 2021
Some thing short circuit at its main circuit board. Probably, it should be with its main amplifier section circuit. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
https://elektrotricks.blogspot.com/
You can get an idea about the fault to an extent. Search the site by type in the brand name and model of your set, in its search bar at the right side column, and press enter.
JVC Televison &...
Answered
on Mar 12, 2021
After a lamp replacement, you should perform a lamp time reset. Did you done that? If you wish to get some details; check the site linked here. Pull up older posts.
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the brand name and model of your set, in its search bar at the right side column, and press enter.
JVC Televison &...
Answered
on Mar 06, 2021
try unplugging the unit. Press and hold power button for 10-20 sec's then try again
JVC Televison &...
Answered
on Feb 28, 2021
There might be an issue with your TV"s power supply and the power supply is going bad for your TV and needs to be replaced.
JVC Televison &...
Answered
on Feb 27, 2021
