There are 4 A/V inputs on Thomson Home theater system. I have three A/V outputs in the Samsung TV. The question is whether I need 3 pairs of RCA cable to connect from the TV to the Home theater system to make the Home theater speakers function.
SOURCE: No Sound In Home Theater with Dish HDTV DVR Dual Mode Remote Connection
I have a high definition Polaroid tv which I bought in 2007. I have it connected to Dish tv. It worked fine at first. Now when I use the Dish tv remote, the television won't power up. The red light, which appears when the television is off turns blue when I attempt to turn the tv on, but the screen stays black. Why won't the television come on anymore?
SOURCE: no sound though home theater when watching tv
There is an orange button on the remote, half way down in the middle. I belive it has orange lettering and says something like "TV-?" press that, and the sound should start to come through your speaker system. You can then use the original remote that came with your TV and turn the sound off on the TV to use just the theatre system. I noticed that if you use the TV speakers in conjunction with the theatre system, that it echo's.
SOURCE: Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System
If your television has RCA style audio/video output you can use an audio RCA cable (red & white connectors) and simply plug from the 'output' of your television into the auxilliary input on the back of the HT-BD2.
Then select AUX on the HT-BD2 remote, whenever you wish to listen to the television audio.
SOURCE: Hook-up Diagram for Samsung HT-Q70 Home Theater System
try to download the user manual here http://www.samsung.com/us/support/download/supportDown.do?group=audiovideo&group_cd=&type=hometheater&type_cd=03030000&subtype=hometheatersystems&subtype_cd=03030100&model_nm=HT-Q70&dType=D&mType=&model_cd=&menu=download&menuLink=/support/download/supportDown.do&prd_ia_cd=03030100&disp_nm=HT-Q70&isEqualsY= let us know. thanks.
SOURCE: v ipod mode in Samsung HT-Z420 home theater system not working
Plug a yellow video cable into the TV (IN) and the Sound system (Out) then go onto AV1 on the TV or which ever port you plugged the cable into and play a movie and u can see it. A menu doesnt come up like the A ipod funtion so it comes up no signal until u play an actual movie on the ipod. If u dont have a yellow video cable i think u can use the white or red audio ones.
Connecting an Amplifier / DVD Home Theater
TV Rear Panel
1 Audio Cable (Not supplied)
Amplifier/DVD Home Theater
1 Connect Audio Cables between the
AUDIO OUT [R-AUDIO-L] jacks on
the TV and Audio Input jacks on the
Amplifier / DVD Home Theater.
When an audio amplifier is connected
to the AUDIO OUT [R-AUDIO-L]
jacks: Decrease the volume of the TV
and adjust the volume level with the
Amplifier's volume control.
Each Amplifier/DVD Home Theater has
a different back panel configuration.
When connecting an Amplifier/DVD
Home Theater, match the color of the
connection terminal to the cable.
