Panaonic Home Theatre DVD system only plays movies inblack white
Hi. I have Panasonic SC-HT75 home theatre system which is quite old but is awesome.I just purchased a Samsung LCD TV LA32B450 and
when i play movies thru the home system i get a black and white picture.The sound is good and the satellite tv plays thru the LCD fine and i get it in color.
Any suggestions? There is only one yellow slot on the TV and i have used it for the satellite tv.
Cheers!~
Steve
Posted by hoover152 on
  • hoover152 Jul 06, 2009
    Thx mate. The side panel has a red , white , yellow (AV 1) which i use for the satellite tv and that's all good.
    Component 1 and 2 have a red , white , blue & green and i used the yellow video cable from the home theatre to plug in to the green and hence get a black & white picture!
    I could swap the yellow cables around when im not watching satellite to watch dvd's....just a pain.
    Thx neway and have a gr8 day.
    Cheers!~
    Steve
Anonymous
    Sniper:
  • 50 Answers
Do u have progressive turned on in the home theater? Does it have the option of component? Are you using the side input on the tv, if you are the component 1 input is also AV1. Green = Yellow
Posted on Jul 06, 2009
Anonymous
    Problem Solver:
  • 11 Answers
Check the region and picture settings on the home theatre's dvd player, it could be set to put out a component signal, or it could be set to a PAL region rather than NTSC
Where can I purchase a cooling fan for my Panasonic DVD Home Theatre Sound System?
How to Fix Panasonic SA-HT75 Fan - Simple Always ON ...
? 2:56
https://www.youtube.com/watch?v=ypL0o5zF_vU
Aug 13, 2012 - Uploaded by Michael "Jack H." Miller
The Panasonic SA-HT75 (and subsequently lots of otherPanasonic ... them from shining: The fan is set to come on and cool your system when the unit ... this out my son he's 8 and he mode yards all summer for a surround sound .... unit but was defective I need the little engine that the dvd is spinning up .
Why do USB video's play through LG Plasma but not through Panasonic SC-BTT190 home theatre system?
Its really a software type problem i have a sony hometheatre that wont play certain videos. When tvs/home theatres are made they get whatever software that is put in witch most videos require the basic stuff sometimes its outdated or just not compatable.
My panasonic sc-btt190 3d blu-ray will not play usb video
Could be software isnt compatable on one but is the other most times its just outdated.
Can I connect a Sony DVD Player DVP-SR90 to the Panasonic Home Theatre SC-HT75 to achieve surround sound without direct SCART connection - and how?
You can connect your Sony DVD player to your Panasonic HT using an analog RCA audio cable (white and red) for stereo sound. Connect to the AUX inputs on the HT and select AUX. Since the Sony DVD player only has SCART, you would need an adapter, scart to RCA. Like this one:
http://www.maplin.co.uk/scart-to-3-phono-plugs-with-in-out-switch-28102
Check for compatibility. Use the red and black RCA plugs for the audio into the HT.
Your Panasonic HT does not have a digital audio input which would be required for multi-channel surround sound (Dolby Digital 5.1)
1helpful
Panasonic home Theatre
You need to obtain audio leads and connect from home theatre directly to audio input in back of tv - be careful as there are normally 2 in back of tv
Open Questions:
 Grubhead
Grubhead
Marvin
Marvin
