SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
SOURCE: error l4 02 in sharp ar5132
Dear sir;the error code you ask about for sharp copier, it means drum motor problem, why don't give them a try to reset before go to replace it, the procedure is
1, press "clear", "pause", "0", "pause"key
2, press 14 then press start.
Have anymore question, please let me know,
HAVE A HAPPY HOLIDAY !!!
SOURCE: error code CE-02 when in the scan mode.
CE-02 = can't find the IP address the copier's been told to scan to.
Open up the web page and look at your scan destinations. Something's changed either there or in the network.
SOURCE: Sharp AR M455N copier scanner will not scan to Windows 2000
Check the webpage under destinations and make sure the IP address is correct for this pc. can get to webpage by opening Network Scanner tool, hitting the scanner tab, then web setup button.
Also make sure the Network scanner service is running in the system tray (by the clock) and that it says the service is started by hovering over it with pointer.
SOURCE: Network Error code CE-02
the ce-02 code is just a communication error it general in nature so you could have a couple different issues going on
