The printer has seen very little use. I was having a cartridge problem, I fit that. Now I have a flashing power button. The printer sounds like it's trying to work then I get a flash from the cancel light and the screen goes black and comes back on. Then it repeats all over again and again. Each time the power button goes off for about 4 seconds.
First of all it require servicing like cleaning of steel rod inside in the printer on which print heads move ,that you can do with lubricant oil and second thing you need to change the cartridges because they may be already dry because you have limited use. In short if you can do this entire thing well otherwise I advised you to show it service center.
Hope this helps. Please rate my response.
Thanks.
Have a good day
