HP Deskjet D2360 InkJet Printer Logo
Posted on Jan 30, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Slow printing - HP Deskjet D2360 InkJet Printer
Vinaya Kumar Kuchipudi
Level 3:
  • HP Master 1,124 Answers
  • Posted on Jan 31, 2012
HP Master
Level 3:
Answers
1124
Questions
Helped
451172
Points
2591
>Refill cartridges causes slow print.. replace with new one
2answers
Why does processing job take long?
the print file detail may be multi-layered may be too much information in print job- your printer memory may not be adequate, you may be printing through a slow network, you may be printing through an older print server which is as slow as parallel port printing or you may be printing through your parallel port which is slow.
Printing in color on my Lexmark printer is very slow. This is a wireless printer and is not so slow on black and white printing.
Printing in color is always slow vs. printing in B/W. If your printing color with the highest resolution setting, it will print really slow. You can adjust the resolution settings in Printer Properties for the Lexmark. If you want faster print, select a lower resolution.
It prints really really slow
Expect pictures to print slow no matter what.
For letters and all text documents set your printer up to print draft for the best printing speed.
Labels are slow on printing req to go faster
By the sound of it you are printing via the serial port, slow printing is normal for the Eltron (EPL) base printers
2helpful
2answers
Printing is really slow almost 10 mins to print i am using Vista and have had updated the driver for vista but still
Epson R230 print slow at PHOTO, very slow at BEST PHOTO, if you do not need photo quality prints try printng at TEXT AND IMAGE for faster printing and the quality is still good. Also try to lower the resolution of that you are about to print, high the resoluton images takes longer time to print. Hope this will help you, Good luck!
1helpful
SLOW, SLOW PRINTING
try saving the things you want to print as a pdf file, then print them from there
3helpful
2answers
Very slow printing
printer hp laserjet 1020 its working when giving first page to print but after gives second page its take time
1helpful
Extremely slow copying
Cartridges may give a very slow printing if internally damaged, or :
When using colored paper in the all-in-one, printing or copying is slow.This issue is a result of the automatic paper type sensor misreading the colored paper as photo paper. The print out takes longer because the unit is printing in Best mode instead of Normal mode.
  1. Click Start , point to Settings , and then click Control Panel .
  2. Double-click Printers and Faxes .
  3. Right-click the appropriate all-in-one, and then click Printing Preferences .
  4. Click the Paper/Quality tab and under Type is: select Plain Paper . This sets the default paper type setting to Plain Paper.
Hope this helps.
k24674
Grand Canyon Tech
Grand Canyon Tech
