-Try restarting your pc.
-If the problem persists then unplug your router for about 15 seconds.
-If that doesnt work, then remove the code key that you assigned and see if the pc connects then you've simply entered the wrong code key that you assigned.
-If that doesn't then go into your network settings, right click on the network you are trying to connect to and click repair, it will try to diagnose the problem.
- It may be that you changed a setting in the router, try setting it to factory default.
I hope this helped!
SOURCE: "acquiring network address" problem
The password might have been changed that's why you keep getting "acquiring network address", the password is incorrect. What you can do is just reset the router. There's a reset button at the back of it, press and hold it down for 10 seconds then release, unplug the power now for 10 seconds then plug it back in. That will disable the wireless password, just re-enable it.
SOURCE: During setup of the router, once I get to
Have you check the tcp/ip settings at the computer's side? There must be both tcp/ip and dns at auto settings. In case you need more details - steps post me back the operating system that you have.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
oh and the signal strength states exelent connection.
