20 Most Recent Buffalo Technology WHR-G54S Wireless Router (WHR2G54S) Questions & Answers
Buffalo-N Nfinity WZR2-G300N Router Setup
Work and play - further and faster! Your AirStation Nfiniti combines Ethernet networking with extended wireless range and speed. It offers excellent compatibility with most wireless clients, giving superb performance with Wireless-N, Wireless G, and legacy Wireless-B clients. For best overall performance, use with Buffalo Technology Nfinity wireless clients. System Requirements: • A high-speed (Broadband) Internet connection or existing local area connection. • A computer with a network connection (wired or wireless) and a good web browser. The screenshots in this manual were taken with Firefox, but Netscape and Internet Explorer are also supported in versions 4.5 or later, and Safari 1.0 and later are supported with Macintosh OS X 10.2 and later. Package Contents: • WZR2-G300N AirStation with built-in antennas • AC adapter • CAT5 LAN cable • Utility CD with Manual • Quick Setup Guides • Warranty Statement see link for details and a fix for your issue http://cdn.cloudfiles.mosso.com/c85091/WZR2-G300N_Manual_web_new.pdf
1/2/2018 5:57:37 AM • Buffalo... • Answered on Jan 02, 2018
I dont remeber the password
You can reset your Buffalo router by pressing and holding the reset button on the back of it for 4-10 seconds. The IP address to sign into the router will be 192.168.11.1. The username will be root and the password should be left blank. The following website has more information on your router also.
4/3/2017 9:55:21 AM • Buffalo... • Answered on Apr 03, 2017
Cant get on buffalo main page
jasedrisk
consult the manual that came with the equipment
every manufacturer have their own default ip address use in loggin into the router main page
4/3/2017 9:54:03 AM • Buffalo... • Answered on Apr 03, 2017
I have a WHR-G54S router and I have only been using it for wireless connections to internet. I now want to use a hardwire port to access the internet. Can you point me to how to do that
That Network Appliance is really THREE different devices in one. A Router A Wireless Access Point A 4-Port Switch All you need to do is to connect an Ethernet cable from the Network adapter in your PD, to one of the 4 switch-ports on the back of the router+ device; which one does not matter.
1/3/2017 9:42:42 AM • Buffalo... • Answered on Jan 03, 2017
How to configure
The WHR-G54S has a default LAN IP address of 192.168.11.1 and Subnet Mask of 255.255.255.0. Make sure your computer has an IP address in this range 192.168.11. x Open your browser type http://192.168.11.1 you will enter the web interface of the router root is the username and no password is needed. Configure your router. http://cdn.cloudfiles.mosso.com/c85091/WHR-G54S-Manual-v1.9-web.pdf
3/23/2014 1:32:01 AM • Buffalo... • Answered on Mar 23, 2014
0answers
I forgot my password and username of my wifi
If your laptop is Still connected to Internet you can use the below ways:
  • Windows 7/8: Right click on Wifi connection name>> Select Properties and then check the Show Characters box. Doing this will display the password.
  • Windows Vista: Right click on Wifi connection name>>Select either Connect or Disconnect. Then, select Properties, check the box next to Show Characters and retrieve your password.
  • Windows XP: You will need to download WirelessKeyView, which is explained in the next section. If your laptop is not connected to Internet:
  • You need to reset the Wifi Adapter.
12/5/2013 3:40:16 AM • Buffalo... • Answered on Dec 05, 2013
2answers
I can not get connected. Woke up this morning and
Hello, the local only means you have connection to the router but the router does not have connection to either the modem. Did you try resetting the modem?
Turn off both devices (router and modem) turn the router on first. Then turn the modem. Wait a minute or so and the router should get the IP from the modem and it should work.
If you still have no luck, it means there's something wrong with either the modem or the actual connection from the ISP.
I hope this helps.
7/19/2013 3:22:38 PM • Buffalo... • Answered on Jul 19, 2013
FORGOT THE SECURITY KEY
I couldn't find any instructions for your old router. My only suggestion is try to find a reset switch on it and press it for 15 seconds. If not...buy another NEW router!
1/21/2013 2:42:18 PM • Buffalo... • Answered on Jan 21, 2013
I cant connect i-pad2 to buffalo
Buffalo Technology WHR-G54S Wireless Default IP, Default Username, Default Password
Reset WHR-G54S by holding RESET down while powering it on. Hold 30 seconds, then remove power
11/5/2011 8:32:32 AM • Buffalo... • Answered on Nov 05, 2011
Unable to locate WEP key.
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
8/19/2011 5:24:21 AM • Buffalo... • Answered on Aug 19, 2011
Cant access the username root
This will help...just download the manual...http://www.buffalotech.com/support/downloads/
7/5/2011 3:55:44 PM • Buffalo... • Answered on Jul 05, 2011
Cant open my router
the easiest way to find the IP address of your access point is to utilize the TRACRT function in command prompt.
Open a command prompt window, (XP-run>cmd vista/windows7-find>cmd
in the command prompt window, type tracert (random address ex. www.google.com)
so in the case of www.google.com, the command would be "tracert www.google.com" (no quotes)
the computer will then send a packet to google.com, but list the paths to it, you should only be really interested in the first couple addresses.
The first IP address will be your computers, if your computer goes through a switch before the router, the second address will be that of the switch, the third will then be the routers IP address
If your computer goes directly into the router, the second anddress on the list will be the router's IP address.
type the given address into your favorite browser and the router config page should be displayed.
7/2/2011 6:22:12 PM • Buffalo... • Answered on Jul 02, 2011
2answers
I would like to put
Hello and welcome to FixYa;
connect to the buffalo router via an ethernet cable.. then.
click this link
192.168.11.1
(if link isn't working, copy and paste 192.168.11.1 in a new tab in your browser)
Basic Settings
Wireless
Wireless Encryption (WEP/TKIP/AES)
select TKIP or AES. or you can
Hit Advanced button at top right of HOME page.
Wireless Config > 802.11g,
under Wireless Encryption choose TKIP or AES,
you can input your WPA-PSK (Previously Shared Key)
KittyTech If you need further help, reach me via phone at https://www.6ya.com/expert/carolyn_427ff26936286336
5/31/2011 8:32:10 PM • Buffalo... • Answered on May 31, 2011
Buffalo Technology WHR-G54S Wireless Router (WHR2G54S) Logo
144 questions posted
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Ekse
Muzahura Frank
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Buffalo Technology Computers & Internet
Most Popular Question
forgot security key
  • Computers & Internet
