20 Most Recent D-Link Wireless N 150 Home Router 4Port Switch 80211nbased 150Mbps DIR601 Questions & Answers
Unplug the router.
Plug your computer network cable (if you can and have it) directly into the modem, bypassing the router.
If directly connected modem gives no Internet connection - call your ISP tech support.
If the Internet connection is provided by the modem directly - shut down the router for at least one minute, while shut off, plug the cables from modem back into it, restart router, give it some time to launch services (appr.2-4 min), then check Internet connection on the devices.
If still no joy - 1. Connect your computer to the router (LAN port) using an Ethernet cable. Make sure your IP address on the computer is 192.168.0.### (where ### is between 2 and 254). Please see the Networking Basics section for more information. If you need to change the settings, write down your existing settings before making any changes. In most cases, your computer should be set to receive an IP address automatically in which case you will not have to do anything to your computer. 2. Open a web browser and enter http://192.168.0.1 and press Enter. When the login window appears, login using your router authentication credentials (see it on the back, if you never changed it).
Check internet, LAN and wireless settings (on/off? Firmware updates?).
Check: http://www.dlink.com/-/media/Consumer_Products/GO/GO%20RT%20N150/Manual/DEU_Manual_RevB.pdf
D-Link Wireless... | Answered on Jan 12, 2018
try to connect directly to ISP modem (without router)
D-Link Wireless... | Answered on Mar 26, 2017
First try replacing the LAN cable between the modem and router. Hard reboot bother devices (off 10 sec then back on). Connect to the modem with a LAN cable to make certain it is working correctly.
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
D-Link Wireless... | Answered on Jan 06, 2017
Suggested retail prices are on the company's web-site: www.DLINK.com
D-Link Wireless... | Answered on Feb 02, 2015
did you install a DSL splitter/filter, you need that to avoid interference with the phone.
D-Link Wireless... | Answered on Mar 22, 2014
Ok, there might be one possibility.
Someone might have hacked your router and banned your devices from connecting. Yes, it can be done especially if you are using WEP to connnect to router.
Hardwire to your router using a cable and log in. See what other devices are connected, you also might want to change the wireless SSID name and password, however, do not use WEP, change it to WPS-PSK which is a lot harder to hack.
D-Link Wireless... | Answered on Feb 18, 2014
You are trying to install the router??
If you have driver then you can install the router easily or you can download from manufacturer website and install it.when you install it, setup wizard will automatically come...
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
D-Link Wireless... | Answered on Jan 17, 2013
D-Link Wireless... | Answered on Jan 12, 2013
Use the wizard. There are 2 log in accounts. One for the router admin page. Leave it as is, no real protection when there is a reset in the back. The other is the wireless. The user is referred to as SSID, and the password is known as the KEY.
D-Link Wireless... | Answered on Nov 24, 2012
Connect the ISP modem to main uplink port. Then connect pc to any other port. Done!
D-Link Wireless... | Answered on Nov 11, 2012
If you don't know the password to the router you can hold the reset button (small hole on back) for 10-15 seconds to reset to factory defaults. Login using admin admin for user and pass, or blank for pw.
D-Link Wireless... | Answered on Sep 25, 2012
Hi, this seems to be either an issue with your router's hardware or local computer wireless adapter hardware. In order to determine which one is it do the following:
1. Go and check the LEDs on your wireless router to see if there are any blinking or switched off as stated in the official manual documentation for DLink products (can be found here or here more specific).
LEDS are as follows (left to right - per official user manual/doc):
- Power LED = A solid light indicates a proper connection to the power supply. cdekatrr_0.png
- Internet LED = A solid light indicates a proper connection to the Internet port. This LED blinks during data transmission. cdekatrr_1.png
- WLAN LED = A solid light indicates that the wireless segment is ready. The LED blinks during wireless data transmission. cdekatrr_2.png
- Local Network LEDs = A solid light indicates a connection to an Ethernet-enabled computer on ports 1-4. This LED blinks during data transmission. cdekatrr_3.png
2. Check the laptop's or desktop wireless adapter if it is disabled or enabled and if is disabled enable it by going to your computer's Control Panel (either winxp or vista/win7) and go to network connections (in vista/win7 put the control panel in detailed view to see more options) and then right click on your wireless connection and click enable.
3. In a case that also the wireless adapter is enabled but you still cannot see any access points/wireless networks please go to your current wireless connection and right click go "Diagnose", this feature is mainly available in windows 7 or Vista. For windows XP, go to the command prompt by going to Start->Run->type in the box "cmd" without the quotes->Then type in the following set of commands.
ipconfig /release ---> This will refresh your wireless card IP settings/configuration to 0.
and after that command finishes, type in:
ipconfig /renew --> This will get new settings if the wireless card has problems finding an address from your router.
You can always reset your router (unplug from power supply, wait 2minutes then plug it back in)
or:
Reset the wireless adapter (right click from on the wireless adapter shown in the network connections, disable and then re-enable it) or computer.
Thanks please let me know if you need anything else.
D-Link Wireless... | Answered on Aug 07, 2012
Connect a LAN cable from the D-Link to your laptop/computer'sLAN port, open the browser on your laptop/computer and enter the D-Link's configurationURL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter)You can now change the default admin password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
D-Link Wireless... | Answered on Aug 05, 2012
Try installing a new firmware upgrade to see if that fixes the problem. Just make sure you are careful when installing this as it could ruin your router if not installed properly.
D-Link Wireless... | Answered on May 23, 2012
-Try restarting your pc.
-If the problem persists then unplug your router for about 15 seconds.
-If that doesnt work, then remove the code key that you assigned and see if the pc connects then you've simply entered the wrong code key that you assigned.
-If that doesn't then go into your network settings, right click on the network you are trying to connect to and click repair, it will try to diagnose the problem.
- It may be that you changed a setting in the router, try setting it to factory default.
I hope this helped!
D-Link Wireless... | Answered on May 22, 2012
there must be some memory on the board that isn't functioning properly. Try to do a factory defaults and set it up and see if it sticks. If it doesn't then I would suspect bad circuitry or perhaps firmware issue. You can upgrade your firmware may resolve this issue.
Here is where you can download your manual and download firmware. Do not update firmware through wireless connection!
http://www.dlink.ca/products/?pid=DIR-601&tab=3
To reset the router, locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process. Wait about 30 seconds to access the router. The default IP address is 192.168.0.1. When logging in, the username is admin and leave the password box empty.
The updated version of firmware is level 1.02NA You can check which level of firmware you currently have installed and if its a lower number you can try to update it if factory defaults don't do the trick.
D-Link Wireless... | Answered on May 20, 2012
Try resetting your D-Link router.
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ON until the LEDs flash at the time the release the RESET button. (firmware version was 3.00, and upgraded to 3.05)
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, open the browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
Now configure the wireless card in your computer/laptop with the router's wireless settings.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
D-Link Wireless... | Answered on May 10, 2012
I think you should try to reset and reconfigure the router.
Connect your computer directly to the modem and make sure that Internet is working through the modem.
Connect the modem and computer to the router and try to reconfigure it.
See how to setup router
D-Link Wireless... | Answered on Mar 20, 2012
D-Link Wireless N 150 Home Router 4Port Switch 80211nbased 150Mbps DIR601 Logo
Popular Tags
91 questions posted
Top D-Link Computers & Internet Experts
Mike
k24674
Muntejaya Ginting
Muntejaya Ginting
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • D-Link Computers & Internet
Most Popular Question
go about
  • Computers & Internet
