Power comes to lcd monitor that is to switch. but no display is coming
SOURCE: HCL Monitor type HCM580M display problem
Information about the Linux / UNIX less command.
Thus, various display problems may result, such as long lines being split in the wrong place. -R --RAW-CONTROL-CHARS, Like -r
Device Manager information and help
This section will also display what COM ports are detected; for example, ... CODE 13 - System Failure - Possible problem in Device Driver or Windows 95 Code.
Good Luck, Please dont for get to Vote, Thank You.
SOURCE: LG Monitor L194WT - Indicator Lights Flashing
sorry - i posted my response at the original thread : )
Comment by ohms, posted on Jun 19, 2008
Definitely it is not your
computer. When it was given the signal to go OFF, it did but like
completely off.
Comment by ohms, posted on Jun 19, 2008Oh one more thing, if the
monitor still exhibits same issue after setting your Power Options as
displayed above,
check your warranty with that monitor and exercise it.
Yep u got it ! warranty or new monitor
SOURCE: monitor stops display
Hi...there,
It's seems your LCD Monitor backlight inverter it burnt out. Need a new inverter. Have a nice day!
SOURCE: Power Light Blinking & Black Screen
A blinking blue light indiactes that your power-inverter board is not
putting out what it should. It needs an overhaul which may be a simple
as changing out the capacitors on the boards.
It could go beyong that to transistors or even a bad bulb.
It will have to be opened up to do that.
A picture may show visual signs of damage. If you can take one and email it to me , I'll take a look.
Fran
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series
