SOURCE: HP L7580 SCANNING PROBLEM
The paging file size may be set to low.
Let me know if the 2 individual documents are fine....
O/s & microsoft office version.....
SOURCE: HP LaserJet 2840 Scanner problem
Yes, but I don't see any actual paper jams. I have a Vista O/S and I've been reading that that might be the problem; the 2840 scanner driver is not compatible with the Vista O/S and HP hasn't produced a solution yet. I appreciate your efforts, thanks.
SOURCE: Save scanned document in PDF
Well I have this problem too.
The HP's link guest posted above is in simplified chinese, for those who doesn't understand chinese, and is too lazy in translating them, here is a brief translation done by myself.
HP is acknowledged of this problem, this is basically caused by the incompatibility between HP's OCR engine and form tables in the scanned documents.
"As HP's OCR engine is kinda elementary, and is not supposed for professional uses", said HP, they suggest users to reduce the complexity of scanned documents by limiting the scanned regions. The best way would be by eliminating image objects, or just scanning text within a form table. (Well that would be kinda lame and stupid.)
Well if you DO need to process documents with forms, "Get A Professional OCR software" and forget about HP's imaging software, it's what HP says.
Wish this would help.
SOURCE: scanning multiple pages into one Word document
Scan all, then copy to the word document. You can edit your file into small so that you can put several file in single pages.
