Samsung YP-Z5 MP3 Player Logo
Anonymous Posted on Oct 23, 2011
I need a replacement usb cable to connect my samsung YP-Z5 MP3 player to my computer
Anonymous
Level 3:
  • Master 2,574 Answers
  • Posted on Oct 23, 2011
Anonymous
Master
Level 3:
Answers
2574
Questions
0
Helped
621480
Points
8053
You can purchase a replacement USB cable for Samsung YP-Z5 MP3 Player from amazon >>LINK
  • Anonymous Oct 23, 2011
    Thanks Jack, This has been a great help.
    Cheers, Paul.
Samsung 1gb yp-z5. wont charge, usb disabled. PS havent got any other usb ports to try, no keyboard additions.
Try to take apart the player and disconnect the battery for a few minutes, then reconnect, reassemble and try charging it over the USB cable. It appears that some people have had some success after full disconnection of the battery from player. Alternatively, try eBay for a new battery - there are plenty there.
I have a samsung yp-z5f but i can't get in menu and it keeps freezeing.i reseted it but sill nothing.can you help?
A firmware upgrade may solve the issue. To upgrade firmware follow these steps:
  1. Download the firmware file from the Samsung Download Center by clicking here.
  2. Remember to save the file to your desktop or documents.
  3. Uncompress the downloaded file in a folder (use winrar or winzip). DATA file will be displayed.
  4. Connect the player to your PC with the USB cable.
  5. Right click on the Start button, and then left click Explore to open Windows Explorer on your PC. [Samsung YP-Z5] is displayed in Windows Explorer.
  6. Select the uncompressed files and drag-and-drop it into the Samsung YP-Z5 Data folder.
  7. Disconnect the YP-Z5 from your PC. After disconnecting the USB Cable, the upgrade screen appears.
  8. Select [Upgrade] to upgrade firmware.
Try it and see.
Samsung YP-U3 not recognised. This device cannot start. (Code 10)
  1. Connect the USB cable to your computer.
  2. Press and hold the menu[0].jpg button while plugging the other end of the USB cable into the YP-Z5.
  3. When the display shows USB Connected, release the menu[0].jpg button.
  4. The device is now in USB mode.
  5. When through, you must safely remove the USB device. Note: To safely remove the USB device, right click the USB icon ( usb_icon.jpg ) in the bottom right of your screen, and then click Safely Remove Hardware.
  1. Upon disconnecting the device, it will return to MTP Mode.
I have no idea how it happened, but i plugged it into my computer to charge. and then i just saw my mp3 player and the screen froze and it says usb connecting and when i plugged it out it still said usb...
1helpful
4answers
SAMAUNG-YP-Z5,LOW-BATTERY
Try getting a new USB Cable.
I myself have had the Same Problems.
And that seems to help.
How do you down load music from CD on to your YP-Z5 MP3 ?
you should have a usb cable to connect the player to the pc.
if you have a music folder, open it, choose files you want to load, open edit at the top of the page, hit copy, then open the disk in my computer that is the player, and hit paste under edit at the top tool bar
Connection to my computer
UMS mode allows the Z5 to interface to the computer as if it were a removable hard drive. You can then use Windows File Explorer to manage the files in the Z5.
To get into UMS mode, connect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
If you upgrade to the new firmware, you have the option of making it always connect in UMS mode.
The steps to install the latest firmware are:
(1) Download version 2.37 or newest of the Z5 firmware http://www.samsung.com.
(2) Unzip it to get the file named "Z5Update.dat".
(3) Disconnect the Z5 from the USB port.
(4) Reconnect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
(5) Open a File Explorer window, and find the YP-Z5 device.
(6) At this point, make sure the Z5 is fully charged and has at least 30MBytes of free space.
(7) Copy the file "Z5Update.dat" to the root directory of the YP-Z5 device.
(8) Now disconnect the Z5 from the USB port.
(9) The Z5 will display the option to upgrade to the new software, or to cancel.
(10) Select "Upgrade". This will power off the Z5.
(11) Connect the USB cable to the Z5. Now it will upgrade the firmware under USB power. DO NOT DISCONNECT THE USB UNTIL THE UPGRADE FINISHES. After finishing the upgrade, new firmware will be started automatically.
(12) Check the version information in the "Settings > System Info > Version" tab.
Now you can turn on the UMS only option.
Settings / System Info / UMS Only = On
Doodles1
7helpful
6answers
Samsung YP-z5 won't connect to the PC!
This might help getting it connected to the computer.
3answers
Can I cahrge my Samsung mp3 player using my ipod shuffle docking station
you cant't charge the mp3 like that because samsung and ipod are tow diferrent companies and if you could you might enup frying your mp3 so try buyng the car charger for the yp-z5.
I can't connect my samsung yp-z5 to the computer!!!
Try installing the Samsung Media package supplied with the player. Then restart your PC - all programs should then recognise the YP-Z5
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
