Question about Samsung YP-Z5 MP3 Player
Samsung 1gb yp-z5. wont charge, usb disabled. PS havent got any other usb ports to try, no keyboard additions.
Posted by cpearce40 on
coralsoft
    New Friend:
    Problem Solver:
  • 6 Answers
Try to take apart the player and disconnect the battery for a few minutes, then reconnect, reassemble and try charging it over the USB cable. It appears that some people have had some success after full disconnection of the battery from player. Alternatively, try eBay for a new battery - there are plenty there.
Posted on Jul 29, 2011
I have the yp z5 model and it wont charge and the comp. wont recognize the device either. im guessing i should replace the battery because all of the components inside are still intact.
May 03, 2011 | Samsung YP-Z5 MP3 Player
Samsung YP-z5 won't connect to the PC!
First thing you can do here is to reset the unit to its default settings so all settings will be clear and that will help fixing this problem....and also try connecting this unit to a different computer and check if it will be conencted fine because if it will stay connected to you can update of flash the software for this ....
Oct 14, 2008 | Samsung YP-Z5 MP3 Player
My Samsung YP-Z5 player wont respond to charging. Tried plugging into several USB ports on different computers but wont charge. Its constantly displaying .... Low Battery & USB Disabled. I was...
Yes, they only last two to three years.
A search of eBay, a place i look to check availability gives a number available.
Search "Samsung YP-Z5 battery"
If you are able to open up the case You could cut off the existing battery leads close to the battery and join the two wires. Soldering is preferred if you have an insulated tip soldering iron.
Otherwise twisting the wires together is probably good enough.
Tape the joins to strengthen and insulate them.
Feb 08, 2011 | Samsung YP-Z5 MP3 Player
SAMAUNG-YP-Z5,LOW-BATTERY
Try getting a new USB Cable.
I myself have had the Same Problems.
And that seems to help.
Feb 10, 2008 | Samsung YP-Z5 MP3 Player
Connection to my computer
UMS mode allows the Z5 to interface to the computer as if it were a removable hard drive. You can then use Windows File Explorer to manage the files in the Z5.
To get into UMS mode, connect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
If you upgrade to the new firmware, you have the option of making it always connect in UMS mode.
The steps to install the latest firmware are:
(1) Download version 2.37 or newest of the Z5 firmware http://www.samsung.com.
(2) Unzip it to get the file named "Z5Update.dat".
(3) Disconnect the Z5 from the USB port.
(4) Reconnect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
(5) Open a File Explorer window, and find the YP-Z5 device.
(6) At this point, make sure the Z5 is fully charged and has at least 30MBytes of free space.
(7) Copy the file "Z5Update.dat" to the root directory of the YP-Z5 device.
(8) Now disconnect the Z5 from the USB port.
(9) The Z5 will display the option to upgrade to the new software, or to cancel.
(10) Select "Upgrade". This will power off the Z5.
(11) Connect the USB cable to the Z5. Now it will upgrade the firmware under USB power. DO NOT DISCONNECT THE USB UNTIL THE UPGRADE FINISHES. After finishing the upgrade, new firmware will be started automatically.
(12) Check the version information in the "Settings > System Info > Version" tab.
Now you can turn on the UMS only option.
Settings / System Info / UMS Only = On
Doodles1
Dec 31, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
My YP-Z5 unresponsive
There is a reset button at bottom by the usb connection port, try pressing that i had similer problem downloaded the manual from samsung site which said try doing that so i did and now it seems to work fine
Nov 18, 2007 | Samsung YP-Z5 MP3 Player
This might help getting it connected to the computer.
Sep 29, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Can I cahrge my Samsung mp3 player using my ipod shuffle docking station
you cant't charge the mp3 like that because samsung and ipod are tow diferrent companies and if you could you might enup frying your mp3 so try buyng the car charger for the yp-z5.
Jul 04, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Samsung YP-Z5 MP3 Player Logo
151 people viewed this question
Top Samsung Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
