This tv have a dead highvoltage deflection circuitries area.The arching sound u hearing are from the dead FBT-the flyback transformer and those highvoltage circuitries components parts trying to powering up those tv 3 CRTS-Tv tubes.This tv problems,must be pair by a qualify tv Tech.If u want to save this tv.Must tries check many tvs shops for the best estamate and prices for repair.Tv must be repair by a professional.Tv can't be repair by a hobbist or an amature because this tv problems require alots troubleshooting on the highvoltage deflection circuitries area and by replacing the FBT and many other parts on that highvoltage circuitries area.
Stick in a little something like a tooth picker into the power on button. Mine goes off when I don't
Ok so here is a sequence of the heater lighting and the solution for your problem...
1. Thermostat calls for heat.
2. Draft inducer motor starts.
3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes.
4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas.
Solution:You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks.Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. Please see "limits, rollout switches & furnace control boards" further down on this page. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning. Please see the pictures below to help you identify a flame sensor.
Thanks and I hope this helps. Feedback apprec.
