When the refrigerator is powered on, the display goes through a self-test and then all the sensors are checked. In case there is a malfunction, an error code is displayed on the display. If there is no error, the display would stay off until you open the door or trigger the display.
Ask Samsung customer service toll free number.
SOURCE: hole in freezer
there is a way using a special resin but it is not a reliable repair and you will then need special gear to regas
write it off
SOURCE: Kenmore Elite Trio 22.4 Cu Fridge - Flecks of "Tin Foil" in Ice
Perhaps the solution to to change out the ice maker unit
SOURCE: GE Side by Side Stainless steel Ice Maker water will not shut off
The fill valve may hae a chunk of debris such as rust in it. If you disconnect power and water, you might disassemble the valve if it's the type that was screwed together. If it's riveted, you'll have no choice but to replace. In either case, make sure you have a filter in the line so this does not happen again.
