20 Most Recent Samsung 26.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum Questions & Answers
Your model has the twist tray style icemaker. The part number for you front section that contains the motor assembly is DA97-00258E Ice Maker Assembly. You can try by taking it out and seeing if the tray will return to the home position but stopping there make me question if the thermal fuse in wiring harness may have blown. We may need to test that wire also to see if the thermal fuse is still good, I will leave you some of the links and ready to help when you need me, Thanks, Sea Breeze
Samsung 26.1 Cu.... | Answered on Apr 29, 2019
A lack of refrigerant or a compressor problem might be the cause of freezer low efficiency but that is unlikely to blame for the buildup of ice in the refrigerator.
A certain amount of ice is normal and initially in the evolution of the fridge there was a need for routine deicing, typically just a few times each year. Later a heating element was included to ease the task of defrosting.
These days the heating element is now automatically switched on briefly every time the cooling cycle finishes and the resulting water drained into a cup mounted on the compressor. The heat from the compressor evaporates the water and the fridge remains frost-free.
I expect your fridge should be frost free and clearly the auto defrost is not working. This shouldn't be a great problem and if everything else was good it would just mean routine deicing like the early days. Clearly everything else is not good and the buildup of ice is much more than normal.
Assuming it isn't caused by an elementary mistake like placing hot food in the cabinet there are two main causes of excessive ice buildup - one is a defective door seal and the other is failing cabinet insulation, the latter marked by the compressor needing to run longer to maintain a low temperature and parts of the outside of the cabinet feeling "chilly".
Samsung 26.1 Cu.... | Answered on Oct 05, 2017
When the refrigerator is powered on, the display goes through a self-test and then all the sensors are checked. In case there is a malfunction, an error code is displayed on the display. If there is no error, the display would stay off until you open the door or trigger the display.
Ask Samsung customer service toll free number.
Samsung 26.1 Cu.... | Answered on Aug 01, 2017
The main circuit board is right behind and part of the control panel.
Samsung 26.1 Cu.... | Answered on May 11, 2017
There are two posible causes fot the trip of the RCD. The reason for the RCD to be trips off it means that a power cable is connected with a metalic part or earting of the fridge. So the first is the compressor if it burn out but since in your case it is working for sometime then this less possible. But it have a small chance that the starting kid to be the problem. The second case is when the defrost starts the defrost heating element is conected in series with the defrost thermostat and if the element or thermostat it have been burn out that one reason why the RCD can be trip off. Yoy can use this link which will help some more http://www.youtube.com/user/SamsungFridgeFreezer
Samsung 26.1 Cu.... | Answered on Sep 12, 2011
If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Samsung 26.1 Cu.... | Answered on Sep 04, 2011
sounds like you have a problem with the defrost heater. hope this helps.
Samsung 26.1 Cu.... | Answered on Aug 08, 2011
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
heatman101
Samsung 26.1 Cu.... | Answered on Jul 03, 2011
Samsung 26.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum Logo
54 questions posted
Top Samsung Refrigerators Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Refrigerators
Most Popular Question
samsung rs2577sl ice maker not drop
  • Refrigerators
