Hi sirbeverly,
You may want to attempt a Repair - instructions for this process are specific to each model. You can find valuable Support resources by visiting www.philips.com/support and enter your model number (listed on the product itself, typically starts with "SA").
If you haven't already done so, you can reach Customer Support at 1-888-744-5477. An agent will also be able to walk you through this process.
Hope this helps! Rate and comment this solution!
REPAIR INSTRUCTIONS:
Try doing a soft reset first.
Note: Your songs and data will not be lost or corrupted by a soft reset.
If soft reset does not work, then you may have to use the Device Manager to REPAIR/RECOVER your player (Note: For some models, a Repair can be performed using Philips Songbird).
If you have not already installed the Device Manager, follow the on screen instructions to install the Device Manager from the installation CD or download the latest version of the Device Manager application from http://www.philips.com/support.
Once the Player is disconnected from the computer, the display will show "Firmware Upgrading" for a couple of seconds and then start up as usual.
Tip: Update your player's firmware to the latest version to reduce the chance of future hang-ups. See "How do I update my player with the latest firmware?" for instructions.
If you have any additional questions or issues, Consumer Care can be reached at 1-888-744-5477.
Hope this helps! If so, please let me know by rating this solution so that I can help others more effectively!
