SOURCE: Monitor goes black
Does it show a picture in safe mode? If it does you might want to install drivers specific to the Monitor if you can find them.
SOURCE: Samsung SyncMaster 915N monitor
Go into advanced settings from the settings tab of "display properties" and select the "monitor" tab, from there, try changing the refresh rate. Toggle "hide modes that this monitor cannot display" if you do not see any other settings in the drop down other than the one that is already selected.
SOURCE: it saysmy pc video resolution is out of range
to chabge resolution go to click start
control panel
apperance and themes
display
settings
and down towards lower left hand you'll see screen resolution
then move bar to 1024*768
Mark
SOURCE: Screen resolution not available on Display menu
The 1920x1080 resolution has to have two things.
First, make sure you download the latest driver from Samsung Support site. I have the T240, and love the extra high resolution, but you have to have the driver installed.
Also, to get the resolution, your graphics card in the computer has to support the high resolution. You need to check the graphics card Mfg's website, and download and install the latest driver.
That should get you up and running, as long as the graphics card supports that high. Some of the older ones might not.
SOURCE: syncmaster 710N resolution problem
no,
the LCD display don't harm the eyes cause don't spreed radiation.
preferred resolution 1280x1024 at refresh rate of 60Hz is not optimal.
the samsung 710N can easy handle 75Hz at 1280x1024 so just change it.
