20 Most Recent Sharp LC-15AV7U 15 in. LCD Television Questions & Answers
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Sharp LC-15AV7U... | Answered on Jan 17, 2019
then it is probally the lights
Sharp LC-15AV7U... | Answered on May 02, 2016
You need the remote control to shut off the sleep timer. There is no other way to do it. Buy another remote control.
Sharp LC-15AV7U... | Answered on Aug 29, 2015
the screen driver on the back of the screen may need cleaning or has over heated. it may just need a clean or it may need replacing. try cleaning the board and screen connectors first.
Sharp LC-15AV7U... | Answered on Sep 16, 2013
The main board to this TV should be checked.
Sharp LC-15AV7U... | Answered on Jul 25, 2013
Some JVC sets and other brands have this issue--You might want to contact the maker to see if this is a known issue and if a software/firmware upgrade is available.
On a lot of the sets you may have to replace an expensive board if no upgrade is available---On several of the JVC sets (for example) we have at our shop had to go to the site, download up grade on a sim card and manually install it for color wrong, lettering backwards or upside down etc.
There are in any set like these be a board that processes all info to the screen and if confused or bad will create this kind of problem.
Sharp LC-15AV7U... | Answered on Apr 18, 2012
Checked all track in line of tuner if you have multimeter checked volteg on tuner pin as return on board.
Sharp LC-15AV7U... | Answered on Jan 21, 2010
Check your closed caption settings via the on screen menu, if on, turn off.
Sharp LC-15AV7U... | Answered on Nov 06, 2009
if the HD input is damaged then you will need to replace the mainboard.
Sharp LC-15AV7U... | Answered on Jul 08, 2009
Menu on remote and make sure you have it on wide screen or 16 to 9
Sharp LC... | Answered on Jan 17, 2019
Hello
If your Roku 3 player is not connecting to WiFi, it is possible that the WiFi signal from the router is out of range. In order to strengthen the signal, move the router and Roku 3 so that there are fewer objects and walls between them.
For any help or support just visit us: www Roku Com Link
Sharp LC... | Answered on May 26, 2018
Sharp LC-15AV7U 15 in. LCD Television Logo
15 questions posted
Top Sharp Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
LC Sharp
  • LC Sharp
Most Popular Question
print tv screen backwards
  • Televison & Video
