Element Electronics FLX3210 32 in. LCD TV Logo
rose Posted on Sep 07, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Head are cut off on my elenment tv 1080 - Element Electronics FLX3210 32 in. LCD TV
Jerry Kramer
Level 3:
  • Element Elec... Master 3,933 Answers
  • Posted on Nov 01, 2013
Jerry Kramer
Level 3:
Answers
3933
Questions
Helped
882289
Points
12076
You need to go into the video set up menu. There you will find different video display options such as 4:3, 16:9, letterbox, cinema...etc. Select the one that gives you the best resolution for your viewing. There may be other options in there as well for Vertical adjustment.
Can you adjust resolution on a Philips 60pp9202/17f
Your tv goes up to 1080i. But it will only display the resolution its given, such as a (DVR,Cable,Satelite,GameConsole(wii,ps,xbox)) has its own resolution and whatever resolution it is at is what the tv gets and displays. Same if it runs thru a Surround sound that only supports certain video resolutions such as 480 or 720 and not 1080 then it will not display a 1080 resolution even if your tv can. The only way you would change the resolution on the tv is if you did it in the first place for some reason or a old school antenna mix up (unlikely). Also just in case the aspect ratio is not the same as resolution so just in case your trying to get rid of black bars or have cut off image or to get a rectangle or square image thats not the same and usually can be adjusted.
tip
Convert TM900 1080/60p and 1080/50p AVCHD MTS footage to ProRes 422 for Editing...
Edit TM900 1080p 28Mbps AVCHD MTS to ProRes 422 in FCP
The HDC-TM900 High Definition Camcorder is a HD offering from Panasonic.While you record 2D videos in 1080/60p (1080/50p for PAL model) at 28Mbps with Panasonic HDC-TM900 .If you would like to put the AVCHD videos from TM900 to Final Cut Studio for editing, a third party software shall be needed to handle the 1080/60p and 1080/50p footage to ProRes 422 for FCP 6/7. Aunsoft Video Converter for Mac is the recommended Panasonic TM900 AVCHD to ProRes converter for high quality video editing on Mac with less compressed Apple ProRes format.
Apple ProRes 422 , Apple ProRes 4444,introduced in Final Cut Studio, was advertised to one of the codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro.
Here is the step-by-step guide for you to Convert,import and edit Panasonic HDC-TM900 MTS to Apple PreRes 422 MOV to Final Cut Pro/FCP7 without rendering on iMac/MacBook Pro with Mac OS X like Snow Leopard.
Step 1. Load Panasonic HDC-TM900 videos to Aunsoft Video Converter for Mac.
Run Aunsoft Video Converter for Mac as the best MTS video to ProRes converter on Mac, click the "Add" button and you can browse the TM900 28Mbps videos for conversion.
Step 2. Choose Apple ProRes for Final Cut Pro.
Click the "Format" option, and navigate the mouse cursor to Final Cut Pro > Apple ProRes 422 (*.mov) as output format. The video to ProRes 422 converter will transcode Panasonic HDC-TM900 1080p AVCHD to Final Cut Pro native format.
Step 3. Choose 1080p size with 60 or 50fps.
Click the "Settings" button and choose 1920*1080 from the video size drop-down box to keep the original HD resolution. Click the drop-down box for frame rate, and choose 60fps or 50fps as output video frame rate. The frame rate option depends on your source videos in NTSC or PAL model. Click the OK button to save the changes and the Mac AVCHD video converter will convert 1080p AVCHD videos to 1080p ProRes 422 Mac FCP compatible native format.
Step 4. Convert 28Mbps MTS to Apple ProRes for FCP.
Click the convert button under the preview window, the conversion from Panasonic TM900 AVCHD to ProRes 422 MOV Final Cut Pro Native Format will start immediately.
After converting and merging the Panasonic HDC-TM900 AVCHD files, just import the output Apple PreRes 422 .mov files to Final Cut Pro 7 or Final Cut Pro 6 for editing and the video is in HD 1920×1080.Optimize your workflow and save time with the Apple ProRes compression for Final Cut Pro.
How do I get the proper aspect ratio on my LCD TV?
What is your picture source? If it is a cable box or a satellite receiver the pix format can be limited or adjusted there, not in your TV.
Striped calaber blts
Cut the bolts off with a die Grinder.
Bernina 1080 cuts thread in reverse
Hi, is the top tension too tight? as this is often the problem. Try loosening it
Hope this helps,
Sally
Just recently my sharp aquos lc 40 e is stuck in stretch of wide screen and the heads or top of things are being cut off. When i go to view mode it only gives me 4 options wide, stretch dot to dot or zoom...
Not all TV programs are broadcast in 1080. When you use zoom or stretch on a program in 720 or 480 and a 1080 program is viewed you have to go back and take off zoom and stretch to get a correct picture.
2answers
How do I set my tv to 1080
You don't set your tv to 1080. You set whatever you are connecting to your television to 1080. Let's say it is a cable box or blu ray player. You would need to be connecting it to your television with an hdmi or component cable. Connect it only once to the television with an hdmi or component cable. This may sound ridiculous but there are people that have their devices connected to the television three times with three different types of cables (hdmi, component, composite) instead of just one. Make sure the television is on the proper input. Adjust the video output settings to reflect 1080 i or p if possible resolution.
2answers
Samsung LCD TV LN40A550P3F will not support 1080 format when hooked up to HDMI via Directv receiver.
Hi, is the directv box giving out 1080? There is an option on the box to select between 480, 720, 1080.
Also the tv has the same option.
BLUE RAY 1080 (p) PLAYERS INHANCE VISUAL HD ON 1080 (i) tV
try to see if u have hdmi slots and check the highest resolution it can go.there is a higher resolution called hdcp,with not div x but dvi-d where resolution can go up to 20000
RCA TV RCA D61W20, Weird Problem
did you adjust the set in both modes 1080 and 480? They both need to be done seperately.
Top Element Electronics Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
