Equalizers are generally connected via the tape in and out sockets.
However they do tend to affect surround settings, so you only be able to use it with the stereo mode activated.
Hey!
You can improve your connection stereo sound go to change your setting of Equalizer, definitely improve your quality of sound.
If face any problem in Epson Printer, please visit my site.: https://epsontechsupport.net/
You may have to adjust the EQ7 Preset to XPLOD and then listen to the jam. Here are the instructions from the bt3100u manual:
Selecting the sound quality
- EQ7 Preset
You can select an equalizer curve from 7 equalizer curves ("XPLOD," "VOCAL," "EDGE," "CRUISE," "SPACE," "GRAVITY," "CUSTOM" or "OFF").
1 During reception/playback, press the select button.
2 Rotate the control dial until "EQ7 PRESET" appears, then press it.
3 Rotate the control dial until the desired equalizer curve appears, then press it.
4 Press (BACK).
The display returns to normal reception/play mode. To cancel the equalizer curve, repeat the first 2 steps then select "OFF" in step 3.
Tip
The equalizer curve setting can be memorized for each source.
We hope that this helps. If not please return and post how this went.
Which type of device so you have it set to?? DVD/DVR, TV, SAT-CAB, AM/FM..etc? Because some of them only give u a certain equalizer an some give multiple.
If nothing else, get the manuals for the preamp and the EQ. You'll probably have to pay for them.
Google it.
Akai PR-A04 preamplifier << This is the control center and where everything comes together.
Akai AP-D210 turntable (ONLY to jacks that say "PHONO"
Akai EA-G40 Stereo Graphic Equalizer (in the Tape 1 Out/In set)
Akai CS-F14 Stereo cassette deck (in the Tape Out/In set of the EQUALIZER) *
Akai AT-K110 Fm Am Tuner (to the Tuner inputs)
Akai DT-100 Audio Tuner (to the Aux inputs)
Akai PA-W04 Amplfier (to the amp outputs)
* This will allow you to Equalize the Tape on the Record or the Playback side.
Read some audio magazines or websites. Get to understand Tape Monitor Loops.
yeah that is because Harmon makes JBL speakers and Crown amps..for Yorkville Speakers use the VTC DLMS4080 Speaker processor, it blows the Drive PA away...
Equalizer You can control the sound quality when or diminishing frequency bands. Select Menu > Fun & Apps> Media > Equalizer. To activate a set, scroll to one of the equalizer To view, edit, or rename a selected set, select Not all sets can be edited or renamed.
Stereo widening Stereo widening enhances the audio output of the phone by enabling a wider stereo sound effect. To change the setting, select Menu > Fun & Apps> Media > Stereo widening.
