Beverage-Air DP93 Refrigerator Logo
Posted on Aug 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Standing water in the bottom coolers of my prep table.
Robert Moller
Level 3:
Guru:
  • Master 1,524 Answers
  • Posted on Aug 23, 2011
Robert Moller
Master
Level 3:
Guru:
Answers
1524
Questions
Helped
580064
Points
4327
The drain is clogged. Check the fitting on bottom of evaporator for a vinyl hose, remove it and using a funnel poor a mixture of baking soda and warm water down it. It will then flow to the heated condensate pan. http://www.beverage-air.com/images/undercounterWorktop/manuals/809-049A.pdf
True prep table leaking water.
The drain tube that drains out the water is plugged. It runs from inside the cabinet to under the refrigeration unit outside the cabinet. Try to clean it out with a can of compressed air used to clean keyboards and see of that works.
2answers
Holding water in bottom of unit
drill a hole and insert a piece of tube from home depot 3.00
2answers
Compressor never comes on
I made video how to replace compressor on true air beer cooler, should be the same for most of prep tables and etc. Hope That helps someone. REPLACING COMPRESSOR TRUE AIR BEER COOLER R134A
Freezing
Keep the prep top table pans covered when not in use. Never leave empty holes where pans should be. If the pans are empty put a couple of inches of water in them to keep some heat load there. Check the door gaskets and door seal on the base doors. Make sure the thermostat is set on number 5. If all of this checks out probably need a new thermostat, but if it's erratic I suspect you will find it's one of the former problems.
What are the minimum and maximum operating temps for a beverage air sur72-30m prep table cooler?
Most all manufacturers try to build units to hold between 34 to 38 degrees as this is the most commonly accepted range for coolers by all Health Departments.
Why is there water pooling in my sandwich make up table? My reach in cooler, also?
During the cooling/freezing cycle condensation forms, this drips into a pan and then is evaporated by a heating element.
One of two things could be wrong.....
Your drip pan is clogged
or
your evaporator unit is bad
Hope this helps
Kairak prep cooler
there are defrost heaters in this unit also the fan that is on the top plate could be resting in water. put the init into a defrost and after all the ice has melted clear the drain line thats by the fan on top. while your are looking check the wireing to the axiel fan there.
Top Beverage-Air Refrigerators Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Jorgie  the...
Jorgie the...
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
