20 Most Recent Beverage-Air DP93 Refrigerator Questions & Answers
If the temperature control adjustment wont warm it up my guess is that someone has been on the system with gauges and the refrigerant charge is wrong. Make sure the temperature sensor is attached securely and properly placed. The refrigerant charge is critical and if it isn't weighed in by the ounce exactly it will freeze.
Temperature control measures coil temperature not cabinet temperature. Hope this helps and good luck.
Beverage-Air... | Answered on Oct 18, 2014
The drain is clogged. Check the fitting on bottom of evaporator for a vinyl hose, remove it and using a funnel poor a mixture of baking soda and warm water down it. It will then flow to the heated condensate pan. http://www.beverage-air.com/images/undercounterWorktop/manuals/809-049A.pdf
Beverage-Air... | Answered on Aug 23, 2011
It's been my experience that in most cases, it is very difficult to get the exact amount in that is on the tag. A 5 ft. hose can hold up to 3 oz. of liquid and on small systems, it will drive you nuts. Always go with what you know. Charge the unit to proper pressures and watch it for a while to see if it is doing what you want. The charge may have to be 'Tweeked" to get it right.
Beverage-Air... | Answered on Nov 28, 2010
Hi, Am sorry, when you brake down the cabinet, you will be unable to assemble it back ,cause you will damage where to fix it screw to assemble it back.
Take care.
Beverage-Air... | Answered on Jul 15, 2010
There is no"filter" underneath. There is. however, a tray underneath your fridge, designed to catch any excess water. If you remove the bottom louvered piece in the front on the fridge, you will find, probably on the right hand side, a tray which is engineered and designed to catch any excess water (as if the fridge were defrosting), but there is no "filter" which I know about. Refrigerators are pretty simple machines. They don't typically require lots of maintenance, but they do require monitoring here and there.
Beverage-Air... | Answered on Jan 18, 2018
you type in their e-mail address and see if you get a reply
most likely you will get an undelivered reply so it will not be legit
Beverage-Air... | Answered on May 27, 2017
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Beverage-Air... | Answered on Jun 20, 2015
yes sounds like a bad defrost terminator or timer?
not allowing it to go into defrost so compressor runs all the time and it frreezes up
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Check ur cold control thermostat, ur thermistors in both fridge and freezer ( they should be checked for both ohms and for amount of current being put out as per ur model ), ur air flow vent from freezer to fridge.( to make sure it opens and closes without any restrictions) On thermistors check for A close circuit and amount of ohms not just an Ohm reading. As per ur model. Most should atleast show 1200 ohms. Also Check door seals for leakage.
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
FAN check to see if it is operating or restricted A fan that is not blowing or restricted will not circulate the cold air properly.
Often, the first thing that folks do when their refrigerator starts to feel warm is turn both controls on the coldest settings.This is exactly the WRONG thing to do.Turning the cold control to the coldest settingwillkeep the compressor running longer and make lots of cold air.
But turning the air door to the coldest settingclosesthe airway to the food section. Lots of cold air is made, but most of it stays in the freezer section, and the food section actually getswarmer.
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
THE COMPRESSOR:
If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor, relay and or capacitor is overheating or not getting proper power and will not start.The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, some located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
Lastly you should also check ur THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 13000 ( give or take 150 ohms) ohms is required.
Read more:http://removeandreplace.com/2013/10/31/fix-refrigerator-freezer-wont-cool-freeze/#ixzz3WDEo5NDJ
REMEMBER GOD IS THE REASON FOR GOOD ADVICE"
Refrigerator Is Not Cooling What To Check And How To Fix
Evaporator coils
Condenser
THE COMPRESSOR:
Evaporator coils
Condenser
THE COMPRESSOR:
Evaporator coils
Condenser
THE COMPRESSOR:
Read more:
http://removeandreplace.com/2013/10/31/fix-refrigerator-freezer-wont-cool-freeze/#ixzz3WDEo5NDJ Refrigerator Is Not Cooling What To Check And How To Fix
Evaporator coils
Condenser
THE COMPRESSOR:
REMEMBER GOD IS THE REASON FOR GOOD ADVICE" Refrigerator Is Not Cooling What To Check And How To Fix
in diff areas depends on model?
see pics
There are no instructions. Valves need to be brazed onto service pigtails after market. The usual techniques of line taps, reclaim, braze permanent Schrader gauge port valves, evacuate, and critical charge is used. Not the good old days any more.
If it needs gas it has a leak. These coolers generally don't come with gauge access ports and need to be silver brazed into place. These systems have a critical charge and will not operate right unless the exact ounces of refrigerant are in the system. The temperature controls measure coil temperature instead of cabinet temperature. The wrong charge makes them run and run and they cant control temperature. Hope this helped.
Beverage-Air DP93 Refrigerator Logo
11 questions posted
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Marvin
Marvin
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Beverage-Air Refrigerators
Most Popular Question
beverage air model dp93 tag states 9 5
  • Refrigerators
