20 Most Recent Beverage-Air Kegerator - Beer Keg Cooler Refrigerators DD48 2 Keg Space Saver by Beverage Air Questions & Answers
There is 2 kind of compressor location on those beer coolers. I have video of both. Hope that helps.
Beverage-Air... • Answered on Sep 02, 2015
replace the rubber seal gasket in the hose connector
Beverage-Air... • Answered on Apr 28, 2015
There are sixteen (16) ounces in a pint.
Beverage-Air... • Answered on Oct 10, 2014
One US gallon is about 3.785 litres. One UK gallon is about 4.546 litres.
Beverage-Air... • Answered on Oct 01, 2014
Sounds like a relay has burned out and you may be low on R134A
Beverage-Air... • Answered on May 12, 2013
It can take a very long time to get a keg of beer down in temperature. The heat transfer from a keg is slow due to the lack of air circulation inside the keg. You should also check your condenser coils, make sure they are clean. Door gasket should also be in good repair. Hope this helps.
Most evaporator fans run all the time. This is mainly to use the air flow to assist in melting off any frost build up during the compressor off cycle. If that fan shut off with the compressor the coil will have a tendency to freeze up. :)
Beverage-Air... • Answered on Apr 29, 2013
It sounds like you have a bad fan motor. Call a service company out. They should be able to fix it. :)
Beverage-Air... • Answered on Jul 11, 2010
128 ounces to a gallon
Easy to check. Jumper thermostat terminals, it it starts replace.
Beverage-Air... • Answered on May 01, 2010
Came with R-12. You can use MP 39
Check to see if any of the compressor electrical items came loose when moving.
I had this happen to a customer and he called someone else in who tried to sell him a new compressor.
You would need to be a certified refrigeration technician to even buy R-12, since it is a CRC refrigerant. The kegerator probably doesn't have service ports so you would either have to braze a low-side port in or use a piercing valve, and fix wherever the refrigerant leaked out from. Basically, by the time you pay a refrigeration tech to do all this, it isn't worth it and you would be better off buying a new one
Beverage-Air... • Answered on Jul 26, 2009
Refrigerators Logo
Popular Tags
32 questions posted
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Beverage-Air Refrigerators
Most Popular Question
beverage air kegerator seems work
  • Refrigerators
