20 Most Recent
True Refrigerated Sandwich Prep Table 72" 30 Pan Questions & Answers
Coils freeze
Either your coil is blocked with paper or wrap, or you have a refrigerant leak in the coil and the little bit of gas that's left is flashing as it enters the coil. Make sure that the cooling coil and condenser is clear and the fans are running. That's all you can do without refrigeration tools. Good luck and hope this helps
10/18/2014 4:03:49 AM •
True...
Answered
on Oct 18, 2014
Freezing
Keep the prep top table pans covered when not in use. Never leave empty holes where pans should be. If the pans are empty put a couple of inches of water in them to keep some heat load there. Check the door gaskets and door seal on the base doors. Make sure the thermostat is set on number 5. If all of this checks out probably need a new thermostat, but if it's erratic I suspect you will find it's one of the former problems.
3/30/2014 8:25:52 PM •
True...
Answered
on Mar 30, 2014
My pizza prep-table freezes everything.
Hi
Sounds like you are correct, unless the door seals are not in good order, air leaking in can fool the thermostat.
If it has a top section that the pans for pizza ingredients sit in check that the airways are clear and that the tins and lids fit properly.
Regards
Gordon
4/27/2011 7:42:12 AM •
True...
Answered
on Apr 27, 2011
