Question about Beverage-Air BM23
My bev air bm23 kegerator wont cool. the fan works like it is suppose to inside 24/7. The fan outside works as well. There is a hhhmmm sound and then a click. It thought it was the compressor so i took the back apart and found the clicking coming from RELAY (TI) (9660-071-161). I have no idea what that does. Could it be that easy all i have to do is replace the relay. Help please!!!!!!
Posted by eazyday on
Northeast Cooling LLC
  • 122 Answers
Yes replacing the relay may fix the problem. You want to replace all the start parts. Overload, relay, and capacitor if one is present. Your unit is probably 1/3 horse power or less. You may be able to install a universal 3N1 starter from Supco, rated at 1/4 -1/3 H.P. If new start gear does not fix the problem you may need a new compressor.
Posted on Nov 09, 2009
I have water in the bottom of my Beverage air kegerator
Water in the bottom of Kegerator - Dispense Forum ' Discuss Keg ...
www.micromatic.com/...kegerator.../kegerators-kegerator.../5907-water-i...
Jul 18, 2009 - I have a Beverage Air 2 with front ventilating compressor. When I .....Also I do refrain from opening my kegerator door between kegs. I have ... need some help with BM23 - Dispense Forum ' Discuss Keg Beer ...
Aug 1, 2013
New To Me Bev Air BM23
Jul 16, 2012
Beverage-air condenser / thermo
Dec 31, 2009
Beverage Air BM23 Door Not Sealing
Aug 3, 2009
More results from www.micromatic.com
Kegerator leaking water inside - Home Brew Forums
Dec 28, 2015 | Beverage Air Refrigeration DD58C-1-B - 59...
How do I get the right temperature in a beverage air BM 23 Kegerator
either a problem with the thermostat or the probe for it has been dislodged and getting a false temp reading
May 18, 2014 | Beverage-Air BM23
Kegerator not cooling
which fan , inside or out.. if outside condensor fan is running then it has a bad 175 capacitor or if the compressor is running then it is low on refrigerant. if the cond fan is not running then check thermostat.. you can do this by connecting the two wires together.. another way to check the compressor, cond fan is to reach under and unplug the wires going to comptessor and plug into a 12ga extention cord.
Nov 17, 2013 | True Direct Draw Systems: Kegerator...
I'm trying to find out the age of my Beverage Air BM23 Kegerator. It's serial number is #823620I.
Scott,
Your Beverage Air Kegerator model BM23 / serial: 823620I - that serial didn't bring anything up when I called the manufacturer but based on the first 2 digits of the serial and the roman numeral 1 at the end of it - it would appear that your unit was manufactured in 1982 (If that number was on a metal tag then it defiantly was 1982).
We specialize in cooler gaskets and can help you locate the gasket part your unit needs. We also are able to get many other hardware and accessory parts for Beverage Air units and other manufacturers. Let us know if we can help.
Matt at coolergaskets.com
[email protected]
855-288-2259
Aug 25, 2013 | Beverage-Air BM23
Beverage Air Kegerator Runs constantly gets too cold
yes sounds like a bad defrost terminator or timer?
not allowing it to go into defrost so compressor runs all the time and it frreezes up
Apr 29, 2013 | Beverage-Air Refrigerators
I have a 901650 intertherm and the fan outside turns on but the air conditioner inside does not work. What could it be?
!st off, do you mean the indoor unit does nothing period as wont run? or wont cool?if it wont run, the checking breakers/fuses etc is a waste of time, as the transformers clearly providing the 24 volts to operate the contactor outside.If you switch your fan to "on" does the fan run?if not, check fan relay, or board or motor/cap etc.If the fan does run with the fan switch set to on, but not in cool mode, the auto function that sends power to green /fan via yellow?cool terminal in the tstat is open and not allowing the 24v to energize the fan relay.
Feb 24, 2012 | Heating & Cooling
I have a beverage air kegerator that seems to work fine, but the evaporator fan runs constantly. Is it supposed to run constantly, or is it supposed to cycle on and off with the compressor, etc.?
Most evaporator fans run all the time. This is mainly to use the air flow to assist in melting off any frost build up during the compressor off cycle. If that fan shut off with the compressor the coil will have a tendency to freeze up. :)
Aug 13, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
I have a BM23 Beverage-Air kegerator. It was working great until a blackout last week. I had a surge protector on the unit, but ever since then, the temp. would stay around 48-50 degrees. I had an...
electrician do one thing, electricity. If the unit cools, the compressor is running. a power outage should not put the compressor in a "Weaken" state. I would check the starting components. don't overlook your surge protector causing a voltage drop. try running the unit without the protector.
let me know if I can be of any further help.
Mar 14, 2008 | Beverage-Air BEVBM23 Commercial Beverage...
Beverage-Air BM23 Logo
1,283 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Marvin
Marvin
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
