The freezer not freezing, first inspect that is the fan in freezer running or not running.If the fan is not running then problem is with fan.Get the fan checked.Also many a times frost gets build up on the fan blades and that blocks the fan from running.In that case it has to be defrosted.--------
The actual cause of freezer not cold, is weak compressor.When the compressor gets weak, the freezer section will cool less.And then slowly --- slowly it will stop getting cooled and later on it will effect the fridge section cooling too.---------
READ the working procedure of your refrigerator.-------
The
working procedure of this unit is as follows: --- The compressor starts then it
cools the freezer section. When the freezer reaches its cooling level the
defrost cycle starts functioning. In this cycle the fan in the freezer section
starts running and the cool air in the freezer section is passed to the fridge
section and the fridge section gets cold. The air from freezer to refrigerator
passes from the section, in that section the damper is located.------------ But as you mentioned that
freezer not cooling this indicates problem with compressor.When compressor
cools the freezer section then fridge section gets cold.If freezer section is
not getting properly cold then fridge section will not cool properly/.So the
problem relates to compressor.---------- In the compressor there is a
refrigerant called FREON.With the help of this Freon the compressor cools the
freezer section.Freon is a gaseous type cooling agent.The compressor will stop
cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon
is possible, but the cost for that recharging is approx the cost of new
compressor.So its always advisable to get compressor replaced.Because new
compressor has warranty for few years.------------------ You can get required parts
from from online sites like: --- www.repairclinic.com or from searspartsdirect
online site.
But before you get replaced any thing, first try reset procedure, its called defrost reset procedure:----
The manual defrost
reset procedure is as follows : ----
First unplug the unit from main power outlet. Then empty whole unit
completely. Then keep both the doors open. Wait for 24 hours. All the ice
collected on the coils and in the freezer section will get melted.
Clean the water from the sections. Then Connect the power cord of the unit to
main power outlet after 24 hours/.Then set the temperature to normal in both
fridge and freezer section. Then check, if the same problem is noticed, then its compressor issue and needs to be inspected.---------
When the top half of a freezer is not working properly it is a sign that the air circulation within the freezer is not functioning. In other words, the freezer refrigerant is still working properly, but the cold air it produces isn't going anywhere: Instead, it is sinking to the bottom of the freezer (heat rises) where it does an excellent job of keeping that half of the freezer cold while missing the top section entirely.
The air circulation problem is usually caused by a fan issue. Find where your fan connects to the refrigerant system and pumps the air out into the freezer. If the fan blades are stuck or frozen, you may be able to loosen them or replace the fan. If the fan works mechanically but does not turn on the problem lies with the motor instead. In this case, you can replace the motor or call a professional it may also be fan or evaporator
