Question about GE Freezers
I have a side by side GE unit. The bottom of the freezer compartment keeps the food frozen but the upper half of the freezer will not freeze. There is a motor or a fan running on the freezer side and frost building up on the back wall of the freezer from the bottom to half way up. Any thoughts?
Posted by paulcarother on
  • paulcarother Mar 06, 2011
    it is self defrosting
  • Anonymous Mar 19, 2014
    could it be from not enough food in freezer
Ryan Nguyen
    Sergeant:
    Champion:
  • 342 Answers
Try to defrost the freezer and see if the air valve opens and closes properly if all of that works then there is a problem with the fan that moves the cold air into the refirgerator
Posted on Mar 06, 2011
  • Ryan Nguyen
    Ryan Nguyen Mar 06, 2011
    Even so out fridge did that and it is self defrosting also try that and let me know the result
My freezer keeps already frozen food frozen but wont freeze fresh food
You need to put it at the top of the freezer in an upright freezer which is usually where the circulation fan is. With chest freezers you put them in the bottom. You may be able to make the freezer colder by turning the thermostat dial to a higher number. The higher the number the colder the compartment will be.
Get yourself a cheep fridge and freezer thermometer from Walmart. They have a green section where the red line should be. The freezer should be minus 18'C or 0'F.
http://i.walmartimages.com/i/p/00/07/23/97/00/0007239700696_300X300.jpg
Nov 03, 2015 | Freezers
Upper part of freezer not freezing
  • When the top half of a freezer is not working properly it is a sign that the air circulation within the freezer is not functioning. In other words, the freezer refrigerant is still working properly, but the cold air it produces isn't going anywhere: Instead, it is sinking to the bottom of the freezer (heat rises) where it does an excellent job of keeping that half of the freezer cold while missing the top section entirely.
  • The air circulation problem is usually caused by a fan issue. Find where your fan connects to the refrigerant system and pumps the air out into the freezer. If the fan blades are stuck or frozen, you may be able to loosen them or replace the fan. If the fan works mechanically but does not turn on the problem lies with the motor instead. In this case, you can replace the motor or call a professional it may also be fan or evaporator
Dec 07, 2013 | GE 13.7 cu. ft. General Electric Upright...
Alarm going off and half freezer not freezing
Make sure it's not due o excessive frost buildup.
Oct 16, 2013 | Whirlpool 247 cu. ft. Upright Freezer...
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
I have a Zanussi Freezer Model ZFT710FW. The alam and red light occasionally go off, although everthing appears OK. Temp OK, door seal looks good, etc. After some time the red light goes off of its own...
Dado
Apr 11, 2013 | Zanussi 2.83 cu. ft. / 80 liter Upright...
Sears model 253.9280212 UPRIGHT FREEZER NOT KEEPING FOOD COMPLETELY FROZEN. EVEN AFTER HALF OF CONTENTS HAVE BEEN REMOVED, REMAINING CONTENTS DO NOT COMPLETELY FREEZE. WHAT'S WRONG? HOW TO ID PROBLEM?...
make sure the unit is running and not shutting down to soon if it is change the cold control if unit is staying running the replace unit
May 06, 2010 | Freezers
Brandt apollo fridge/freezer - food defrosts + salad freezes
Check the vents in the fridge side and close a little if you can. On the freezer side just for good measure>>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 05, 2010 | Freezers
GE Freezer Not Freezing
I am not an expert, but if the defrost heater is not working, then maybe when it was unpluged the coils didn't completly unthaw. If not, the freezer still will not cool properly.
Mar 25, 2009 | GE 13.7 cu. ft. General Electric Upright...
Kenmore Freezer chest type 14.8 cubic feet
When you open the freezer compartment do you hear a fan blowing? If no the take off the back cover and replace the fan. The compressor has to be on at the same time for the fan to work. If you know what I mean. let me know what happened. thanks.
Nov 24, 2008 | Freezers
Freezers Logo
101 people viewed this question
Top GE Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Are you a GE Freezer Expert? Answer questions, earn points and help others
