Freezers Logo
Posted on Jan 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our chest freezer isn't keeping food on top frozen although the bottom is still frozen solid?
Anonymous
Level 3:
Genius:
  • Master 1,622 Answers
  • Posted on Jan 11, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1622
Questions
Helped
391870
Points
4742
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Hope this help in solving the problem....
I have a Kelvinator upright freezer model k330uf the bottom section does not work
Sounds like its got blockage.
There is a channel that allows cold air to "fall" into the bottom chamber. There is also a return. Typically the "fall" chamber is choked with either something that fell in and was trapped, frozen solid with ice or algie has grown and closed the hole.
The best thing to do is empty it completely and inspect the drop channel.
Put all your frozen goods in ice chests to keep them from thawing out.
Good Luck.
Freezer runs but won't keep most foods frozen even on coldest setting
Check condenser clean and fan working. Check it's not frozen solid because you've been running it full pelt; if it is, fully defrost it then set it at a mid range setting.
1helpful
How long should it take for a 18 cu ft. chest type deep freeze to get cold?
From room temperature if just plugged in rule of thumb is 24hrs to properly reach temp. Place a glass half full of water in shelf when is frozen solid the unit should be plenty cold enough to keep food. It is always a good idea to get a small fridge thermometer to make sure of temp.
My wife and I bought a Kenmore chest freezer (14.8 cubic foot) about 6 weeks ago. It is made by Frigidaire for Sears, and the model number is #253.165.42105, serial # WB94341279. It has been working OK. ...
This is well with in factory specifications. Hot air rises and cold air drops. Because a chest freezer does not have a fan to circulate the air it is normal for the basket to be warmer than the bottom of the freezer. The bottom of the freezer is used for food you want to keep for a longer period of time.What you store in the basket is food you will freeze for a short period of time. Ice cream should not be kept in the basket. As you fill your freezer with food you will find that the temperature will equal out because the frozen food will take up the place of the frozen air which will give you a more stable freezer temperature.
Try your test when you have it full of food.
Freezer not keeping foods frozen
If this freezer is running all of the time and only freezing the walls at the top inside it is a good chance there is deteriation in the piping in the walls eg (rusty pipes) letting the refridgerant escape (common fault) with chest freezers.If it is more than 7 years old it would be advisable to replace it as the repair would probably cost 3 quarters of replacement price.Hope this helps. Kind Regards.
We purchased a small haier chest-type freezer in 2006. It has worked fine until the past week. It seemed to be running normally, but suddenly did not keep the food frozen solid. There was a little ffrost...
You may have a refrigerant leak. First make sure the lid has not warped and leaving an air gap for heat to enter. That's really about all you can do without getting a tech. involved.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Excess frost not keeping food frozen
you have a refrigeration issue. let me guess. is the frost real thick around a small area not the entire lining? if so you have a restriction or leak. cheaper to replace by the way
My bottom drawer won't open?
Can you supply more info? Was there food in there that could have frozen in a position to lock up the door slides?
Top Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Freezer Expert? Answer questions, earn points and help others
