Maytag Neptune FAV6800AW Top Load Washer Logo
Posted on Aug 17, 2011
My Magtag Neptune TL 6800 started making a horrible squealing noise then smoke started coming out of the washer. What do you the problem may be?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 17, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
273
Points
You need to replace the belt needed to spin the drum. It sounds to me like you may have been overloading the drum, putting too much stress on the belt. Over time, it has begun to " burn rubber" as it spins, causing smoke, or worst case scenario, the motor that turns the belt is locking up as the drum spins causing friction on the belt.
My washer when on spin make a very lould noise. like maybe a bearing is out it is a magtag neptune front load.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
GETTING DC ERROR CODE WITH A GRINDING SOUND AND THEN IT STOPS COMPLETELY
The DC error code is 9 time out of 10 caused by a Clutch Pulley malfunction. The grinding may ne Outer Tub Bearings but need more info. Open the Washer Lid. Spin the wash basket CCW. Do you hear and grinding noise?
The noise may be coming from under neath the tumblers. Further troubleshooting is required.
Do you have basic DIY mech. skills and do you want to save your $1K machine?
If so Google Neptune TL Washer FAV6800AWW
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues that I have helped owners with. I'm an owner of a FAV6800AWW top load machine.
Good luck.
My washing machine makes a grinding noise when it is spinning. It drains alright and seems to work ok, but I`m afraid the grinding noise could lead to bigger problems.
Stone,
All owners are heading toward this issue. I feel your FAV6800A or FAV9800A is at the end of service lifew for the Tub Seal
If you open the washer lid and spin the Washer CCW and hear the noise (Outer Tub Bearing noise) then it's time to role up your sleeves.
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues that I have helped owners with. I'm an owner of a FAV6800A top load machine.
Google this FAV6800A/FAV9800A Outer Tub bearing replacement to see what is involved in doing an Outer Tub Rebuild.
Good Luck
My washer fills with water then it makes a noise like there is something stuck and aggitator won't spin
You need the Service manual to start troubleshooting. There could be something jamed under the tumblers. The Service Manual will get you stareted,
Google this Neptune TL Washer FAV6800AWW
You will find FAV6800A or FAV8800A help.
HAVING AN ERROR CODE (OP) ON MY WASHER TOP LOAD MAGTAG NEPTUNE, WHAT SHOULD I DO?
If you want to DIY the issue Google "Sticky: Neptune TL Washer FAV6800AWW" you can get the Service Manual from that site to help you DIY the fix along with forum guidance.
I discuss the troubleshooting the Left Hand Lid Lock in that sticky.
I can't find my repair notes on this forum no Sticky and no Service Manual.......D*ick
We have a maytag neptune TL. Usually when you hit start to run a load a little water comes out of the discharge hose. It is not doing that. It runs in the wash cycle for about 8 minutes the it pauses...
If the machine is a FAV6800A or FAV9800A google ""Sticky: Neptune TL Washer FAV6800AWW""" Post your problem at this Forum. You will find the FAVA9800A/FAV6800A Service Manual at that site.
If the machine is a FAV6800A or FAV9800A you can go into Service Mode and tes the Drain Pump. Then we can start to troubleshoot the issue if the above model is your machine type.
This site is not really geared up for DIY folks.
Squealing noise during wash cycle
yes thats a belt slipping may have something in the pump maybe a coin or a small item like that.
2helpful
Wont spin with clothes
Common problem with this model I own it. Sounds like the roller clutch bearings in your machine are seized/rusted up. Do you want to try to DIY the repair? Read thru this post for the details of what is involved. Post back with any questions. Rich
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
