20 Most Recent Philips SA2325 (2 GB) MP3 Player Questions & Answers
2answers
How to record music from the computer
Overview of online support for SA2325/02 ( GB ):
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA2325/02&slg=en&scy=GB
Link to the user manual:
http://www.p4c.philips.com/files/s/sa2325_02/sa2325_02_dfu_eng.pdf
Music files MP3 or WMA
Music transfer can be made seeing the player as a USB mass storage device in Windows Explorer, exploring the drives on "my computer": the player should show up as a drive letter with about 2 GB of memory.
The files must have the format and extension as shown on page 17 of the manual:
• Compression format: MP3 / mp3 (8-320 kbps
and VBR; Sample rate: 8, 11.025, 16,
22.050, 24, 32, 44.1, 48kHz),
WMA / wma (64-320kbps)
• ID3-tag support: Song title and artist name
Transferring songs from the computer to the player
After exploring the appropriate music files on the computer, the songs can be dragged and dropped to the memory of the player: read the blue
tips on page 11 of the manual.
Always disconnect the player safely after transfers, see point 3.4.1 of the manual on page 11.
Audio CD converting to mp3 / wma format: RIPPING
When wanting to convert audio CD's to files that can be played on the player, you could use Windows Media Player 11 or MusicMatch Jukebox using the RIP utility.
  • For WMP 11: update your Windows operating system.
  • When using XP MusicMatch Jukebox 10 can be downloaded from next site:
http://www.soft32.com/Download/Free/MusicMatch_Jukebox/4-277-1.html
Right click on the download file under Soft32 Mirrors and select "Save target as..." Rember the download location for executing the file later, having the MusicMatch Jukebox installed.
Need more help ? Just post a comment.
7/6/2016 1:59:45 AM • Philips SA2325... • Answered on Jul 06, 2016
0answers
I need installation software for Philips SA2325 player
can u give me the model no of your mp3 plyer
9/5/2008 12:54:46 AM • Philips SA2325... • Answered on Sep 05, 2008
Freezes PC
your computer may not have enough memory try deleting some unnessecary pictures on your computer and make sure you empty your trash and do a sys scandisk
4/11/2008 3:04:48 AM • Philips SA2325... • Answered on Apr 11, 2008
3answers
I need circuit diagram of philips radio transistor
I need a circuit diagram for Philips Radio Model B4CA49T 1965 model can anyone suggest me where can I get it
1/16/2022 12:47:06 PM • Philips Audio... • Answered on Jan 16, 2022
2answers
I need code for Philips 22DC481/62
Ask Philips: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=ca&userLanguage=en
1/11/2022 4:08:52 PM • Philips Audio... • Answered on Jan 11, 2022
My philips lx3600d was water surged now it does not have volume
Yes it can. contact Philips Support for their local service centre. https://www.philips.com.ph/c-p/LX3600D_69/- ..
12/27/2021 11:52:35 PM • Philips Audio... • Answered on Dec 27, 2021
My Philips DVD Home theater System HTS3544 Everytime i try to play a DVD it won't play it won't will just display Root how can i fix this
TRY USING A CLEANING DISK , IF IT DOESN'T HELP THEN A LOCAL REPAIR SHOP
12/23/2021 9:26:30 PM • Philips Audio... • Answered on Dec 23, 2021
2answers
Philips System 500 Hi-Q dictation machine squeaks on record.
If your new tapes squeak while recording, there could be misalignment in the record path or it could be worn. Curious that no tapes were supplied with the machine. Perhaps you can take the machine to the vendor to demonstrate operation with squeaking.
10/16/2021 7:40:03 AM • Philips Audio... • Answered on Oct 16, 2021
When I push "record" on Philips CkDr760 recorder t the display shows "no analog."
many older units will not work for digital signals
9/9/2021 6:40:37 PM • Philips Audio... • Answered on Sep 09, 2021
Need circuit diagram for philips
I have a service manual pdf there isn't any way to attach it to this message. Give me your email address and I'll send it to you. Or if you have some other way to send it electronically we can do that.
8/13/2021 7:54:23 PM • Philips Audio... • Answered on Aug 13, 2021
2answers
Why is the door of the CD transport on my philips cdr 796 just keep opening even with a CD inserted?
Replace the loading belt and check the timing.
7/2/2021 10:22:23 AM • Philips Audio... • Answered on Jul 02, 2021
Philips sw3440/37 audio inputs D-sub 15 connector pinout
b7ecc65e-ea58-419e-ac45-eaa319918397.jpg this is what i have on mine i used a 3.5 mm jack as an INPUT and i also have a set of female RCAs next i will be replaceing the plugs for speakers and putting standard speaker terminals
5/2/2021 4:27:35 AM • Philips Audio... • Answered on May 02, 2021
How to connect with mobile PHILIPS MODEL NO DSP 3300
This music system is a basic setup so your choices are limited. You could try using a cable connection. The type you need is a "phono jack plug" to "3.5mm jack plug" cable. They are usually very cheap and most TV and Technology Stores will keep them in stock. The cable has different styles of connector at each end. One end is the same as the round red and white plugs at the top of the photograph and the other end is a standard headphones connector. Plug the red and white pair into an 'Audio In' position on the back of the system and the other end into the headphone hole on your mobile phone. (Try the position above the two already in the system). Select the channel on the system for that connector and press play on your mobile device.>
11/29/2020 2:16:49 PM • Philips Audio... • Answered on Nov 29, 2020
Philips SA2325 (2 GB) MP3 Player Logo
12 questions posted
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
 Francisco Mauricio...
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Audio Players & Recorders
Most Popular Question
record music from computer
  • Audio Players & Recorders
