Question about Philips Audio Players & Recorders
Why is my Philips HTS6515/98 power button constantly illuminated red and will not power on?? ?
We moved location and my HTS6515 was working perfectly. Now my Philips Home Theatre System will not power on, the power button is illuminated red constantly. What do I do??
Aron
    Top Expert:
  • Philips Master
  • 2,491 Answers
It could be due to a blown fuse and the fuse that has blown needs to be replaced.Or it could of had stopped working.
Posted on Feb 06, 2023
A 2004 chevy tahoe instrument cluster parking brake light is red,is that due to the overlay or a bulb
If your amber ABS lamp and the red "parking brake" warning lamp illuminate together without any prior pump constantly running problem; the pump motor wires are most likely broken.
The heat shrink tubing that seals the red/black power leads to the motor may have allowed water to enter. The copper conductor turns into a powdery green copper oxide over time due to electrolysis as a small current is applied to the motor all times (even when vehicle is off). The wires will look perfectly intact on the outside even though the copper conductor has been destroyed. The associated error codes will either be C0267 or C0268.
Initial problems will be an intermittent amber ABS and red BRAKE lamp illuminating simultaneously. Over time, the lamps will stay on constantly. In any of the circumstances, you have lost your ABS at all times... even when the lamps are off during the intermittent stage of the system failure.
Dealer specifies pump assembly must be replaced. Not necessary.
The wires can be resoldered to the motor terminal block and resealed with new heat shrink tubing and sensor safe silicone. Do not remove the motor from the pump housing as it is difficult to align the eccentric cam on the motor shaft with the pump mechanism.
This is a common problem that can be solved by resoldering the pump power leads. If the pump runs all the time and the red "BRAKE" lamp has illuminated after pulling the ABS fuse or unplugging the motor; the EBCM (ABS control module) will have to be rebuilt. This can be done for $100.
Both pump motor failure and EBCM failure can be repaired without costly replacement
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
1helpful
Newly installed in a camper from the leisure battery,power to the unit and will load the cd then the unit goes dead.Press the eject button and the unit illuminates and ejects and again goes dead
Do you have power going to both the red and yellow wires? The red wire generally goes to a switched power source and the yellow should be constant. Both wires need to have power going to them in order for the unit to work properly.
Installing aftermarket Kenwood stereo on 1991 Subaru Legacy. The subaru stock wiring does not have a red ignition wire. Can i simply connect the kenwood ignition wire to the Accessory +12v (Yellow/red)?...
Hi, according to my source, there should be an accessory wire that is blue with a yellow stripe. If your is yellow/red, that's fine. You actually should prefer an accessory wire to an ignition wire as there may be less static on the accessory wire. Just make sure the wire does not have power when the key is off. Don't use the illumination wires--they are not needed for the aftermarket head unit and should be taped off.
1991 Subaru Legacy Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red/Green
Car Radio Switched 12v+ Wire: Blue/Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Blue/Red
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Blue/Black
Rear Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Yellow/White
Left Rear Speaker Negative Wire (-): Blue/Red
Right Rear Speaker Positive Wire (+): White/Blue
Right Rear Speaker Negative Wire (-): Blue/Black
3helpful
2answers
Which wire is constant power 4 the radio, and which color is when the ignition switch is on, 91 ford f150?
1991 Ford F150 Truck Car Stereo Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Blue/Red
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
This should help you with more then just the constant power wire, good luck.
2helpful
I am putting in a cd player and i don't understand why it won't get power. i hooked it up staight to battery and it works just don't know which wire is power from the fuse block
1995 Jeep Grand Cherokee Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Red/White
Radio Switched 12V+ Wire: Red/Gray
Radio Dimmer Wire: Orange
Radio Power Antenna Trigger Wire: Green/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Left Front Speaker Wire (+): Green
Left Front Speaker Wire (-): Brown/Red
Right Front Speaker Wire (+): Purple/Yellow
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Doors
Left Rear Speaker Wire (+): Brown/Yellow
Left Rear Speaker Wire (-): Brown/Light Blue
Right Rear Speaker Wire (+): Blue/White
Right Rear Speaker Wire (-): Blue/Pink
Wiring confusion
yellow constant
red switch
black is ground
blue power antenna if any
dimmer i/illumination is optional
front- right-red/green-+
front-left-blue/green-+
rear-right-red/yellow-+
rear-left-blue/yellow-+
these are all the positive side wire for all your spkr
1helpful
2answers
Can,t figure out how to wire it up to my 1995 jeep and would like to find out how to wire it up?
Dont know what model you have so here u go!
1995 Jeep Wrangler Car Stereo Radio Wiring Diagram.
Car Radio Constant 12V+ Wire: Red/White
Car Radio Switched 12V+ Wire: Purple/White
Car Radio Dimmer Wire: Red/Black
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Front Speakers Size: 4′ x 6′
Front Speakers Location: Dash
Left Front Speaker Wire (+): Gray
Left Front Speaker Wire (-): Yellow
Right Front Speaker Wire (+): White/Red
Right Front Speaker Wire (-): Brown/Red
Rear Speakers Size: 4′
Rear Speakers Location: Rear Roof
Left Rear Speaker Wire (+): Gray/White
Left Rear Speaker Wire (-): Brown/White
Right Rear Speaker Wire (+): White/Black
Right Rear Speaker Wire (-): Brown
1995 Jeep Cherokee Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Violet/White
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: Orange
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
window.google_render_ad();
1helpful
2answers
No picture/ power button flashes twice constantly. 2 flash code?
Sorry, but there is no simple answer to your problem.
Bottom line, it needs to be repaired by a qualified technician.
The blinking is a code for what circuit area of the set called for the shutdown.
No matter what it is, there is nothing more you can do.
www.mcveyelectronics.com
NO PICTURE OR SOUND
Hello mtf420ak,
I do not believe this is a problem with a fuse since by your experiment both fuses are good. Now put the fuse back in and if there is still no picture and no sound we can assume that the problem might be some other component on the power supply board, and or the High voltage section because this sounds like a shutdown circuit problem. If it is a shut down circuit problem the section that might be malfunctioning would be the High voltage section of the TV. I would suggest that you let a qualified TV technician troubleshoot and repair this television. I say this because this is not a simple problem, this is an issue that requires a knowledge of electronics and TV repair.
I hope this helps
Shuttle83
http://www.electron-age-technologies-llc.com
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
David Shaub
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
