20 Most Recent
Hotpoint WMA46 Front Load Washer Questions & Answers
My circuit board got damaged as a result of a
You may not be able to have it repaired, depending on the damage. It's hard to find a place that still rebuilds those boards.Could you give me the full model number, and I'll see if I can find you one?
How do I refit the belt on my hotpoint aquarius
(providing yours is front loading?)
The quick answer is 'DON'T'! Purchase a replacement and fit that 'cos the old one will only come off again!
Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT AGAINST THE MOTOR OR FRAME; THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Due to a leak i have no hot water supply to the
Yes provided that the wash required is not for full sterile condition you can have the cold wash using a good detergent.
Choose the appropriate program that does not have the HOT wash and it will progress the cycle.
My clothes do not seem
Mine does this too. I've also noticed that no water is visable through the door window and I'm sure the bottom of the drum should be submerged. I've been adding a bowl of water after the m/c has taken water in, which seems to help, but I don't know what the long term solution is. But definitely get a cloth out and clean the soap unit and housing!
